Quantcast Slip-Joint CV driveshaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Slip-Joint CV driveshaft
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 05-05-2008, 10:55 AM   #1
jonzer12
Anyone using the SlipYoke driveshaft with CV joint from
Driveshaftsuperstore.com
I am preparing for my basic XJ build. It is a DD and I just want to run a 3" lift to run 31's. No crazy wheeling just bushwacking for hunting and occasional trail run. Is this a viable solution? $295 dollars is appealing vs $600 for a SYE+newshaft.
Problems, opinions?
jonzer12 is offline   Reply With Quote
Old 05-05-2008, 11:19 AM   #2
XJNUTTIER
I would say if you are only planning on running the 3' lift, you will not need the sye conversion. I run 4.5" with 31'2 and run my DD and probally a little more wheelin thank you, and no issues, IMOP, it is probally no necessary for your application...
XJNUTTIER is offline   Reply With Quote
Old 05-05-2008, 01:32 PM   #3
ktmracer419
1997 XJ Cherokee
who the heck quoted you $600? i did my sye and shaft for $220
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote
Old 05-05-2008, 01:38 PM   #4
mrboom
1995 XJ Cherokee
Depending on the year of your XJ (-95 or +96 ) at just three inches you will either have very minimal vibes. Or just need a tc drop.
My Jeep Hates Me..
95 Sport. 4.5 homebrew lift.. *Bastard Pack and loving it*
Everytime a Commander Roles off the Lot, a Cherokee Dies.
mrboom is offline   Reply With Quote
Old 05-05-2008, 01:53 PM   #5
jonzer12
I am assuming you got a good deal on a SYE and are using a front drive shaft in the rear.
By the time I pay taxes and shipping + duty (I am a canuck) a
AA or **** SYE + quality driveshaft will run me clost to $600.
I could use a front driveshaft but the time I rebuild the CV and pay for the SYE it will still be more expensive than the above shaft.
Anyone buy one of these things?
Old 05-05-2008, 04:18 PM   #6
bikedude189
1993 XJ Cherokee
that will only mask the problem. you will still wear out the bushing in the slip yoke and then get vibes. i would save up, find a good deal, or not worry about it. i wouldn't trust a cv with a slip yoke tho...
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline   Reply With Quote
Old 05-05-2008, 04:41 PM   #7
SteveJcoYJ
i have no vibes
fill our your specs so we know what your driving
91ish YJ
Originally Posted by sportsdevil333 View Post
ive had girlfriends before and been laid numerous times I just didnt know how to go about with this particular situation since ive never seen a girl do what she did
SteveJcoYJ is offline   Reply With Quote
Old 05-05-2008, 04:43 PM   #8
XJ96PA
i have crazy vibes at 50 mph with 3". i got to get new u-joints like every 3 months. im tryin to do a sye right now but i've been having problem after problem. i dont know if you'd call it a vibration as much as a serious wobble.
XJ96PA is offline   Reply With Quote
Old 05-07-2008, 06:22 PM   #9
jonzer12
How are the slip joint and double cardan related. With 3.5 inches of lift is the
slip yoke really a problem? Hopefully someone on JF as bought one of these things. I suppose however there is a reason why everyone is not running them.
Old 05-07-2008, 08:17 PM   #10
ktmracer419
1997 XJ Cherokee
**** sye and front shaft in rear, just to put it in persective how strong they are, i stripped a dana44 ring and pinion while running it in the rear driveshafts hold up just fine. i just get one that doesnt need a rebuild from the junkyard for $20
97 xj
3" midarmed
Glock Forum
