09-26-2008, 09:24 AM
#1
Which slide hammer to remove wheel hub?
I'm getting ready to replace my front hub assemblies, and reading through various write-ups, I see that a slide hammer is recommended to pull the hub (if it's stuck).
I went to Harbor Freight and found a few. Here's the link:
http://search.harborfreight.com/cpis...mmer&Submit=Go
Which one would be appropriate for the job?
Thanks!
p.s. - Does anyone know what Harbor Freight's return policy is? Just in case I don't actually need to use the slide hammer, I may want to return it.
09-26-2008, 09:45 AM
#2
I didn't need a slide hammer. I just unbolted the three bolts part way, put a socket on one, and tapped the socket with a hammer.
1999 XJ For Sale - Lifted, Leather - PM for Details
09-26-2008, 10:02 AM
#3
x2 you shouldn't need a slide hammer to remove them.
Worst case, you can put your wheel back on and put the lugs on loosely and use that for a slide hammer effect.
09-26-2008, 10:48 AM
#4
When I did the front hubs on my minivan, I bought a Timken (last time and recommend staying away from 'cheap' brands) from Autozone and used their free rental slide hammer. The last hub did not require a slide hammer, it came right off after the 3 bolts were taken off, but one of the other ones did, used this setup attached to the slide hammer:
http://www.autozone.com/R,1807718/st...ductDetail.htm
Didn't take much to get it off, so as others said, you may not need it.
09-26-2008, 11:07 AM
#5
Real Jeeps have dents
. Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
09-26-2008, 11:22 AM
#6
Originally Posted by CJ7-Tim
That saved me about a thousand words! I was going to try to describe that technique. If you have the engine running you even have power assisted hub removal
The only difference was I used a large deep socket but any stout metal object of the appropriate size will suffice.
Rollin on 32'zzzz
Originally Posted by Muddeprived
Who's eric?
Originally Posted by HornedFrogHooah
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
09-26-2008, 11:25 AM
#7
Awesome!
Thanks!
-MM
09-26-2008, 11:27 AM
#8
Three jaw puller... If you have one laying around. Don't go buy tools just for this job. It is a very simple removal.
1998 Cherokee Classic... 2" BB on Moabs
1988 Cherokee Limited... 4.5" RC lift, RK longarms, on 31's. Several homemade skids.
09-26-2008, 11:34 AM
#9
Autozone rents those if you need em
-Chris
2007 JKU- Pretty much stock
1998 XJ- Gone
1992 XJ- Sold
1990 YJ- Sold
09-26-2008, 01:05 PM
#10
Slide hammers and 3 jaw pullers are only for unit bearing/hubs that are bad will be replaced. Using these tools on good hubs for u-joint or axle shaft replacement runs a great risk of pulling the hub apart and ruining it.
The method in the link at stu off-road is preferred because it has an almost zero potential to damage a good re-useable unit bearing/hub.
09-26-2008, 02:34 PM
#11
You are correct CJ7-Tim. I should have posted that as well. But he did say for replacement. Thanks for the correction.
09-26-2008, 08:41 PM
#12
Yes, I'm replacing my wheel hubs.
09-26-2008, 08:54 PM
#13
Thanks to all for their input. I'm going to forgo purchasing a slide hammer for this job.
Thanks again!
-MM
09-26-2008, 09:12 PM
#14
Ok....how bout this - what do you do when 1 or 2 of the 3 bolts holding the hub on breaks. I soaked the p*** outta everything w/ pb blaster and wd-40, tried an impact and air ratchet and nothing. Got out the old reliable breaker bar and started to go to town on those three bolts. 3 of the 6 broke. They wouldn't budge for nothing, now I'm scratching my head trying to figure out what to do. Worst case cenario, looks like I might have to remove the whole spindle and drill the bolts out. Anyone else had this problem and fixed it???
[COLOR="Yellow"][SIZE="2"][B]03 F-250 Super Duty Diesel
01 Cherokee Sport[/B][/SIZE][/COLOR]
[B]Member Of: [COLOR="Black"][SIZE="2"]Empty Pockets Offroad Club[/SIZE][/COLOR][/B]
[SIZE="2"][B]emptypocketsoffroad.org[/B][/SIZE]
[url]http://www.youtube.com/watch?v=uORO_JCaOAY&feature=related[/url]
