Skid PLate Q's - JeepForum.com
post #1 of 5 Old 05-15-2006, 04:42 PM Thread Starter
joeksjeep
Skid PLate Q's
ok i own a 1992 cherokee with the 4.0 and i had 2 questions ive noticed on some newer cherokees or shoudl i say the last production cherokees that they have gas tank skidplates ive seen them on 98's and some 2001's and i was wonderin if anyone noes if those skidplates would fit on a 1992? and another question the frame brace that holds the transmission on my cherokee, i have seen some holes in the frame right behind the trans brace, could you possibly get another one of those trans braces/frame brace and use it as another skid plate so that you have essentially 2 trans braces 1 to hold the trans and the other to be used as armor? thanks im on a tight bugets so im looking for ways to get armor for cheap - joe now for another quick question would a gas tank skid plate forma 1997 -2001 fit on a 1992? thankcs again
joeksjeep is offline
post #2 of 5 Old 05-15-2006, 05:02 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Factory gas tank skid plates fit either 1984 - 1996 or 1997 - 2001. The front and Tcase skids fit all years. The crossmember is really only sheetmetal and wouldn't do much. The factory Tcase skid isn't really worth the cost or bother as it is very flimsy. Aftermarket Tcase skids are much stronger, cover a larger area and are not very expensive.
CJ7-Tim is offline
post #3 of 5 Old 05-16-2006, 02:28 AM
96JXJ
Haleyes & I both have 97+ gas tank skids on 96's. They do have to be modified to fit. They need to be widened about 1/2" & the curved heat shield needs to be cut off. JIM.
96@6 & 92@3
96JXJ is offline
post #4 of 5 Old 05-16-2006, 12:10 PM
Chuck Cook
Understand a tight budget, but you can get the best t-case skid in the door for about $120 - it will be worth it. Good Luck, cjc
95 Cherokee Country (PePe Le Pew) 4.0 Auto
4.56 gears, Aussie Front,PowerTrax No Slip rear (D30/Corp8.25) JKS front discos, no rear sway bar, Rustys t-case skid plate, elastomeric roof coating,
Custom4x4Fabrication rock sliders and diff protectors,
Super Swampers 32x10.5x15 and fender trimming
Chuck Cook is offline
post #5 of 5 Old 05-23-2006, 06:53 PM
ODAMO
Skid plates, Skid plates, Skid plates...
Protecting the under carriage is probably the most Important thing you can do to any vehicle that goes off road. Especially if it's got the tiny stock size tires. You probably should stay outta your Uncle's woods till you protect your bottom BOY.
So what did you find out bout your ignition lock? If you ask on here I'm sure you'd get some straight info on how to fix it.
Uncle ODAMO
ODAMO is offline
JCR t case skid plate vs appalachain armor vs warn t case skid 2doorxj XJ Cherokee Technical Forum 6 02-02-2010 07:08 PM
np-242 skid plate danthejeepman90 XJ Cherokee Technical Forum 2 12-16-2008 12:36 PM
Teraflex Oilpan Skid Question - Also looking for Skid Plate Opinions XJ2000 XJ Cherokee Technical Forum 4 10-17-2007 11:04 PM
Is this a front skid plate or gas tank skid? jeepbro's XJ Cherokee Technical Forum 7 10-03-2007 10:25 PM
Skid Plate Rip off russkrs XJ Cherokee Technical Forum 7 10-14-2005 08:06 PM
