Quantcast Size Request- Shock Bolt Sizes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Size Request- Shock Bolt Sizes
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 09-03-2007, 10:52 AM   #1
Miami_XJ
1995 XJ Cherokee
Hello all, in the middle of replacing my shocks and I need to replace all associated hardware. I need the sizes of the following components..
Front lower shock bolts and nuts
Rear upper shock bolts and nuts
Rear lower shock nut
I believe lower portion on the rear only has a nut securing it? Any info appreciated..thanks!
Miami_XJ is offline   Reply With Quote
Old 09-03-2007, 12:51 PM   #2
hermantherugger
Rear bottom is M12 something...I think 1.25 (but don't quote me). The front ones are nuts & bolts I believe, so you should be able to swap out to standard hardware there (5/16 or something). I'm not sure what the rears are (they thread into the body, so they don't have any nuts with 'em), mine all snapped and we just drilled/tapped to 5/16 coarse thread.
'99 Sport...Custom Front & Rear Bumpers, Rusty's Air Tube, Dynomax Exhaust, Hacked Fenders, Cut 'n Fold Rear Quarters, Durabak'ed Fenders-Rockers-Doors, OME 2" & 265/75R16 Kumho's, Silverstars w/ Upgraded Harness
SOLD
hermantherugger is offline   Reply With Quote
Old 09-05-2007, 11:16 AM   #3
thebestofindica
For the rear upper shock bolts I bought grade 8 zinc plated 5/16" 20 pitch 1 inch long bolts with a washer on top and bottom and nut.
1999 XJ, 242 TC, C8.25, BFG MT 235/75/15, Cragar soft 8 15x7, 4.25 backspace, quadratec HD leafs, OME shocks
thebestofindica is offline   Reply With Quote
Old 09-05-2007, 01:20 PM   #4
Miami_XJ
1995 XJ Cherokee
Thanks for the responses, XJPRO and I ended up using the drill and tap method. We got a bigger bolt and used a washer..got to get back underneath and make sure everything is still tight but I'm sure it will be fine.
Glock Forum
