sisters gearbox bolt cant adjust - JeepForum.com
post #1 of 9 Old 02-14-2011, 09:16 AM Thread Starter
SGTCornewell
2002 KJ Liberty
my sister has a 93 xj 2wd. the steering box needs adjusted. i pulled the elec fan and was very surprised to find a solid bolt without an allen wrench hole in the top of it. anyone ever had this problem? how do i adjust this type of box?
SGTCornewell is offline
post #2 of 9 Old 02-14-2011, 09:52 AM
Mikeand
I suppose you mean so you can tighten a new belt on? Loosen the bolt on the top front, the one on the bottom front that holds the tensioner in place. There are two bolts on the back of the pump that need to be loosened too. then at the bottom right is the bolt to adjust the power steering pump...adjust it, then tighten everything back up..
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline
post #3 of 9 Old 02-14-2011, 09:59 AM
Hussler
1992 XJ Cherokee
No its talking about a different issue.
OP, there should be a nut below the bolt head to "lock" it in place. Loosen this nut, then turn bolt.
Your welcome.
Oh and pics of sis or BAN
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #4 of 9 Old 02-14-2011, 12:48 PM Thread Starter
SGTCornewell
2002 KJ Liberty
you dont wanna see pics. she confirms the myth. just bein honest. on the top side of the gear box, in fords the bolt has a flathead notch cut, jeeps have allen, theres only one lock nut, its brob 3/4 in size.
post #5 of 9 Old 02-14-2011, 01:07 PM
egodfrey
egodfrey's Avatar
Hussler likes those kinda girls
NOW PICS
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #6 of 9 Old 02-14-2011, 01:10 PM
Hussler
1992 XJ Cherokee
I just went out and checked, bolt with a nut on the bottom Perhaps they were changed out in certain years
NOW PICS
Hey if they have a pulse (and sometimes not )
JK thats AWFUL
Hussler is offline
post #7 of 9 Old 02-14-2011, 01:54 PM
egodfrey
egodfrey's Avatar
JK thats AWFUL
Awfully true
anyway
egodfrey is offline
post #8 of 9 Old 02-14-2011, 03:11 PM Thread Starter
SGTCornewell
2002 KJ Liberty
ok, my understanding was that looking down from under the hood, after removing the fan, i would see a nut with a bolt going through it with an allen head cut out of it. am i upside down?
since you wanted it so bad i made my first attempt at uploading a pic. shes not beautiful but shes my sister and she has a wonderful personality.
post #9 of 9 Old 02-15-2011, 07:36 AM Thread Starter
SGTCornewell
2002 KJ Liberty
what, no comments on my little sis?! you guys wanted a pic! ok, i confess, i found this pic on google.
adjust. trackbars with larger axle side bolt? Muddeprived XJ Cherokee Technical Forum 4 01-07-2010 06:45 AM
how to remove gearbox kfeddy XJ Cherokee Technical Forum 3 06-09-2009 05:11 PM
Sisters wreck + wrecked XJ = my parts XJ? Maybe nrpalmer32 XJ Cherokee Technical Forum 10 03-31-2009 06:20 AM
My sisters XJ won't start at random times... Btwngreengray XJ Cherokee Technical Forum 6 08-20-2008 11:10 AM
Leaking gearbox twinsdaddy24 XJ Cherokee Technical Forum 0 03-17-2008 01:42 PM
