Siphoning Gas - JeepForum.com
post #1 of 11 Old 12-29-2008, 06:39 AM Thread Starter
orlimar105
Siphoning Gas
Trying to siphon gas out of my 1997 Cherokee Sport. I stick the tube in until I hit bottom and blow/suck but only hit air. The tank is full so not sure what the problem is. Any thoughts?
orlimar105 is offline
post #2 of 11 Old 12-29-2008, 06:43 AM
rc76
I have a thought.... why???
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...)
99 Cherokee Sport- Stock and Staying that Way (Wife's DD)
rc76 is offline
post #3 of 11 Old 12-29-2008, 07:50 AM
MDub420
1988 XJ Cherokee
Breathing gas = brain damage.
Isn't there a specific siphon/ pump that is made so you don't have to suck so hard?
MDub420 is offline
post #4 of 11 Old 12-29-2008, 08:29 AM
compfreak530
the easiest way iv found of Siphoning gas is to push the hose in and keep blowing till you hear bubbles, ounce you hit bubbles keep pushing a little bit and then only suck with your mouth for a second then put in tank. also i wont be held responsible for any gas that you siphon
compfreak530 is offline
post #5 of 11 Old 12-29-2008, 08:49 AM
Mr_Random
1986 XJ Cherokee
step 1) cut feed line
2) snip/splice into wiring harness.
3) connect correct wires to 12V battery
Result: Self Siphoning tank.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline
post #6 of 11 Old 12-29-2008, 08:54 AM
MattyO
isnt there a little ball or something at the bottom of the fill neck that wont let you push anything into the tank to siphon gas??i thought all cars these days had that . . .
MattyO is offline
post #7 of 11 Old 12-29-2008, 08:56 AM
compfreak530
i think thats only on newer cars. iv siphoned gas out of my jeep 2-3 times. and have had it stolen a few times too >.<. thats when i got angry with razor blades hidden around the gas hole and a locking gas cap. if someone tries to force it open by hand, they`ll be bleeding bad
post #8 of 11 Old 12-29-2008, 06:39 PM
LongueCarabine
WalMart sells a decent little siphon pump for about $10.00. Save yerself some trouble, and at the least gasoline ingestion.
LC
LongueCarabine is offline
post #9 of 11 Old 12-29-2008, 06:50 PM
96cherokeeclass
I see you're from New York... Just a hunch but I bet you have a local expert.
- 07 WK - CRD
96cherokeeclass is offline
post #10 of 11 Old 12-29-2008, 06:54 PM
rockershocker88
1988 XJ Cherokee
i bought a flow and go from homo hardware for like 15 bucks worked like a charm, i like the idea of using the fuel pump good call mr random
rockershocker88 is offline
post #11 of 11 Old 12-29-2008, 07:50 PM
Mr_Random
1986 XJ Cherokee
Homo hardware? sounds... happy...
Yeah we used that trick yesterday, siphoned what was left in the XJ's tank and put it into my dad's van. Took a bit, but was easy.
Jeepus buildicus:
Siphoning Gas Cherokeekid88 XJ/MJ Cherokee Non-Technical Forum 2 10-13-2008 03:51 PM
