Quantcast Single battery with winch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Single battery with winch
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 12-01-2007, 12:51 AM   #1
cnskate
Anybody having any luck running a winch off of a single battery? What's the biggest baddest battery you would suggest for doing so? I'm not running any other power hungry accessories, although I would like to get an Engel fridge someday.
94 4.0 auto 231 w/ 3" OME lift & Tomken discos & Mombasa Excursion Roof Top Tent
cnskate is offline   Reply With Quote
Old 12-01-2007, 08:27 AM   #2
sprintagogo
I haven't fitted a winch to this motor yet but I will be doing and in readiness I have fitted an Optima yellow top. The starting specs are better than the stock unit and I also have the deep cycle ability for when the going gets tough. Deep cycling a stock battery can wreck it within a dozen cycles while the yellow top should be good for over 300 cycles.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline   Reply With Quote
Old 12-01-2007, 08:50 AM   #3
xxxflhrci
I run mine off a single car battery. Just a regular battery, nothing fancy like an Optima, either. My battery is about 8 years old. Yeah, I know it's days are numbered, but it's still starting just fine for now.
xxxflhrci is offline   Reply With Quote
Old 12-01-2007, 01:57 PM   #4
rstarch345
I've been running a single Optima Blue top for four years using a MM 12000 winch. Use it for others as well as myself. It works very well, especially when you upgrade you B+ wiring, like so http://www.soxja.org/forum/viewtopic.php?t=550
Full Specs
2K XJ - 6" lift w/ 34s
'98 XJ Laredo - Stock (and staying that way)
'71 M151
I'm a proud member of MyUniBody
rstarch345 is offline   Reply With Quote
Old 12-01-2007, 03:16 PM   #5
cnskate
So it sounds like one battery might be fine. I'm not planning on using it tons. I'm more into the expedition thing than rock crawling. I could see myself maybe needing to do a long pull across a ford, however. I'm not sure exactly why, but I'm a little more inclined to get a really heavy duty high quality battery over an optima. Seems to be internet rumors floating around of premature failures of the later, plus, there's the price.
Old 12-01-2007, 03:20 PM   #6
gregmondro
I run mine with an Optima red top. Have no problems really, but don't really use the winch all that often. When I do, the vehicle is on as well.
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Glock Forum
