Quantcast single 10" sub location in my jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > single 10" sub location in my jeep
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 04-28-2004, 09:57 PM   #1
skunkmere
whats up everybody, i got a question to who ever can answer it. i got a 1996 cherokee country inline 6. i was trying to figure out where i can descretely place my 10" rockford sub woofer. i was thinking about hooking it some how in that little space accross from the spare. what do you guys think?
skunkmere is offline   Reply With Quote
Old 04-28-2004, 10:10 PM   #2
bmartini
i dont think youll want the magnet that close to the inside of the fender.
[size=-2]2000 Cherokee 4.0L
Scanner in the Glove Box
Silverstar Headlamps
Hella FF75's instead of OEM fogs
Pioneer Stereo Head-unit
Whelen 90 Watt power supply and strobes
Blue Whelen 500 Series Tir6 L.E.D. lights in grill
Switches in the ASH TRAY.[/size]
***9-11-01***NEVER FORGET***
bmartini is offline   Reply With Quote
Old 04-28-2004, 10:12 PM   #3
DefaZ
That's always a possibility. If you've got much wood skills, I would take that panel out and sawzall the compartment out, then make a plate that covers the hole and make your box fill the area behind the panel.
did that make any sense?
You could always make a spare tire box too.. (just take out the wheel)
DefaZ is offline   Reply With Quote
Old 04-28-2004, 10:33 PM   #4
skunkmere
yea i thought about the magnet being close to the fender might mess with the sound, or at least rattle like hell. right. i heard of another idea, to build a false floor in the back and then i cound make a huge sub box.
Old 04-28-2004, 10:46 PM   #5
Bucket110
i wouldn't make a huge sub box for only 1 10" sub...it'll sound like crap. but the false floor would work...leave the rear closed off to the right volume and use the rest as storage. thats what i will do when i put a system in the girls cherokee....that is if i am allowed to play with it anymore
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
[COLOR=blue]NEJEEPZ[/COLOR]
[URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL]
Bucket110 is offline   Reply With Quote
Old 04-29-2004, 01:48 AM   #6
Roll Tide
check out this link. custom sub box
Roll Tide is offline   Reply With Quote
Old 04-29-2004, 11:16 AM   #7
rweso89XJ
I fit a 12" in that spot no problem.
rweso89XJ is offline   Reply With Quote
Old 04-29-2004, 01:20 PM   #8
JeepXJ12
Yea you can probably no doubt fit a 10" in that compartment...How big is your magnet...A 12" would stretch I think unless you have a small magnet or bump out the speaker away from the fender and wall...10" should work without a problem though depending on magnet size...In the future I am going to run either two 12's or one 15 with a sub box built into my false floor...I got pics of my plan I'll see if I can post them...
2000 Jeep Cherokee Sport 4.0L 4x4 auto
16"x8" American Racing Rims
245/70R16 Bridgestone Dueller A/T Revo
SmittyBuilt Brush Guard
ProComp 2" BB lift
Monroe SensaTrack Shocks
[URL=http://www.sounddomain.com/memberpage/499297]My Jeep[/URL]
[URL=http://www.jeepforum.com/forum/showthread.php?p=436360]The Almighty 2" BB Jeep Club Member #27[/URL]
"This Jeep is going in Deep and coming out dirty and wet"......
Black Jeep Club v2.0 Member #12
JeepXJ12 is offline   Reply With Quote
Old 04-29-2004, 03:10 PM   #9
DefaZ
haha nice sketch
Old 04-29-2004, 04:27 PM   #10
Jimi7
Personally I wouldn't cut the plastic trim and use that as part of an enclosure for a sub. Considering the standard rule of thumb for box building is use 3/4" MDF or a high quality plywood, I don't think that 1/8th of an inch of flimsy plastic will cut it, plus the flexing sheet metal will also color the subbass. Then again you may not be as concerned about how panel flex and airleaks affects sound quality and output levels.
I did a fiberglass enclosure. It's actually pretty simple. If you can do brakes, a lift kit, etc, then you should be able to handle fiberglassing. I have some pics of mine on pg 7 of my website Has some links on tutorials on how to fiberglass too.
You just make some templates of out of cardboard for the parts that will be made of wood. Transfer the cardboard templates to wood and test fit the wood pieces and trim as necessary. One you have the wooden frame you just start laying fiberglass. Sure it's more difficult but the difference in output and sound quality would certainly be noticable.
Jimi7 is offline   Reply With Quote
Old 04-29-2004, 06:33 PM   #11
jeepcrawler
hey, can someone do me a favor? can someone measure the depth of that little cubbly space that everyone's installing a sub in? my jeep's in storage right now so i cant measure it. i don't want to do any cutting so i'd like to know just the depth of it. thanks!
jeepcrawler is offline   Reply With Quote
Old 04-29-2004, 11:24 PM   #12
Moose_God
1994 XJ Cherokee
hahahaha! That's the exact same idea I had! Wow, great minds think alike! The sub box with the false floor would work. I was thinking about building a custom fiberglass enclosure on top of the false floor...
94 Cherokee Sport 4wd (converted from 2wd), AW4, NP231 w/SYE, 6" bastard lift, RC drop brackets, IRO trackbar, 33x12.5 Goodyear MTRs, HDoffroad subframe connectors, prerunner front bumper, homebrew rear bumper, flowmaster 40, 96 booster swap., upgraded headlight harness, 4.56 gears (finally!!!)
Moose_God is offline   Reply With Quote
Old 04-30-2004, 05:03 PM   #13
jeepcrawler
hey, question for ya. did you do any cutting back there? if not, how many cu. ft. is behind your board? or how many cu ft is that small space in that quarter panel? thanks.
Glock Forum
