Simple Reason Clutch Pedal will not Depress, after Clutch Job, Missing Pivot Arm - JeepForum.com
post #1 of 1 Old 06-29-2012, 03:46 PM Thread Starter
Darp
After 5 days on and off doing everything down to pilot bushing and doing it solo, put it all together and got in and the clutch pedal would not depress at all. Yikes. Did not want to do the whole job again.
Literally prayed to Jesus about it.
After considering all things pulled the slave out. Put it back in. Noticed that it wanted to push itself back out. Sure enough now it works fine, the rod missed the pivot arm niche.
This is the first thing I would check if after clutch job if the pedal is rock hard.
Cheers
Darp is offline
Brake pedal spongy/delayed after clutch pedal replacement Kasia XJ Cherokee Technical Forum 0 01-29-2012 10:55 AM
Help!!!! I NEED a clutch pedal mxpimpmug XJ/MJ Cherokee Non-Technical Forum 4 12-20-2010 05:58 AM
What's up with the XJ clutch pedal? JWFokker XJ Cherokee Technical Forum 5 09-23-2008 07:38 PM
where is your clutch pedal 82SC XJ Cherokee Technical Forum 2 01-24-2006 10:14 AM
WHHAAAAAAA....clutch master cylinder swap...clutch pedal too short!!!??? 82SC XJ Cherokee Technical Forum 1 01-15-2006 11:17 PM
