Quantcast simple radiator/ transmission cooler install question (pic) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > simple radiator/ transmission cooler install question (pic)
Old 05-09-2005, 07:55 PM   #1
RedJeepXJ
got a simple question, which one of these lines is the return line, as in which one do I hook the cooler up to?
if it matters it's a 1985 3spd auto 2.5L I4
RedJeepXJ is offline   Reply With Quote
Old 05-09-2005, 11:08 PM   #2
RedJeepXJ
the hayne's book is worthless about this, doesn't even say such lines exist
Old 05-09-2005, 11:21 PM   #3
RedJeepXJ
bump
Old 05-10-2005, 01:20 AM   #4
Xtreme 96 XJ
Well you might clean the outside of both lines back where they attach to the trans. case then drive it around for about 8 to 10 mins. then with the XJ idling crawl under it and carefully feel each line.... the cooler one "should" be the return
line.... how about the dealer parts guy.... ask him for a return line.....then peek over his shoulder and ask to see which is the return & exiting line are.
Just some thoughts.....
Good Luck !
Curt (aka Xtreme 96 XJ)
1996 XJ Sport , 4.0, AW-4, Chry. 8.25
Lifted, Locked & somewhat built up....
Some bought & Some Built
Xtreme 96 XJ is offline   Reply With Quote
Glock Forum
