Signs Of a Bad Wheel Bearing?? - JeepForum.com
post #1 of 35 Old 12-05-2008, 09:03 AM Thread Starter
gtospeeding
What are the symptoms of a bad wheel bearing?
I have a 97 cherokee and I hear grone from the front driverside wheel area
(sounds like road noise when someone has oversized tires on their truck) when the jeep is in motion . The faster I drive the louder it gets.
I think its a wheel bearing but when I took it to a mechanic to replace it he tells me the wheel bearing is fine , he then tells me the rotor and brake pads are whats making the noise.
Im no mechanic but the rotor explanation doesnt sound right to me
Their is no steering wheel shake when braking so I dont think its the rotor
any ideas?
gtospeeding is offline
post #2 of 35 Old 12-05-2008, 09:21 AM
boondocksaint
boondocksaint's Avatar
1995 XJ Cherokee
Location: school - Campbellsville, KY; home - Oviedo, FL
jack it up, and see if the wheel wobbles back and forth if you push it...
David
White 95 XJ - Jacked up and abused
White 98 XJ - Stock and babied
boondocksaint is offline
post #3 of 35 Old 12-05-2008, 09:23 AM
Luckyduck
when you get it inspected this is how they check them, they put a bar under the wheel with the jeep jacked up and see if it moves
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #4 of 35 Old 12-05-2008, 09:31 AM Thread Starter
gtospeeding
push it how?
can you be more specific
post #5 of 35 Old 12-05-2008, 09:39 AM
CharlieMopps
1989 XJ Cherokee
Dude, he just told you what you thought was a $500 job is actually a $100-$150 job. Mechanics don't often save you money. I'd tend to believe him.
If you're wheel bearing were going (and I had one fail once) when you turn in a certain direction it will get louder. So, if you turn hard left or hard right it should get louder in one direction, but then seem to go away in the other, because you are either putting more stress on the failed bearing or taking stress off of it, depending on which way you turn.
If your pads have failed to the point that they are now laying against the rotor and ground goves into it... they could cause a lot of grinding to. (I've had this happen before as well) Once the pads ware through to the point that the rivets poke through, they start to grind groves into the rotor. Then the rives fail, the pad false lose against the rotor, and now you have a pad with metal spikes sticking out of it, laying against your rotor... even when you're not applying the brakes it's pretty loud.
CharlieMopps is offline
post #6 of 35 Old 12-05-2008, 09:39 AM
freshlikefruit
put one hand at 12 oclock, one hand at 6, and rock the wheel with it jacked up. if there is any play, you have a worn bearing. dont place you hands at 9 and 3 because that type of play is a steering issue
97 tj, dirt on it
freshlikefruit is offline
post #7 of 35 Old 12-05-2008, 09:40 AM
freshlikefruit
its a pass or fail type of thing, easy check
97 tj, dirt on it
post #8 of 35 Old 12-05-2008, 09:41 AM
CharlieMopps
1989 XJ Cherokee
Originally Posted by gtospeeding View Post
push it how?
hes saying that if you push on the bottom of the tire it should not wobble. But really, your bearing would have to be REALLY bad for it to move. It could still be bad, even if you can't move it.
post #9 of 35 Old 12-05-2008, 09:43 AM
freshlikefruit
if there is no play, the bearing is fine
97 tj, dirt on it
post #10 of 35 Old 12-05-2008, 09:43 AM
Luckyduck
push it how?
i just told you how they do it in inspection stations
CentralMass4wd.com
my build
post #11 of 35 Old 12-05-2008, 09:43 AM Thread Starter
gtospeeding
the pads have atleast 50% left on them and the rotor isnt grooved up
post #12 of 35 Old 12-05-2008, 09:44 AM
freshlikefruit
i would also spin the wheel in the direction of travel to see if the brakes do indeed make any noises
97 tj, dirt on it
post #13 of 35 Old 12-05-2008, 09:46 AM Thread Starter
gtospeeding
if its not the bearing then whats making this groaning sound?
post #14 of 35 Old 12-05-2008, 09:47 AM
freshlikefruit
if it is the wheel bearing, i wouldnt be too worried. it is a unit part, easy driveway fix and they only cost about $100
97 tj, dirt on it
post #15 of 35 Old 12-05-2008, 09:49 AM
freshlikefruit
is it a groan, or a howl? if it is more of a howl, then i would def say a wheel bearing
97 tj, dirt on it
Wheel bearing / Play in wheel ? robert644 XJ Cherokee Technical Forum 6 08-18-2009 04:30 PM
Rear wheel bearing/axle shaft bearing replacement? kadetklapp XJ Cherokee Technical Forum 4 09-02-2008 01:06 PM
signs of a wheel bering going bad/ hub bad? red96jeep XJ Cherokee Technical Forum 5 10-22-2007 05:49 PM
Wheel bearing, single bearing or hub assembly? Ski01xj XJ Cherokee Technical Forum 25 02-25-2007 08:10 AM
Signs your front wheel bearings are failing? thegr8bass XJ Cherokee Technical Forum 3 11-27-2004 01:16 PM
