Significant pull to the right when braking. - JeepForum.com
post #1 of 7 Old 02-13-2013, 12:53 AM Thread Starter
Mitmont
Just had this today, all of a sudden. DPwn the highway and pressing the brakes I was just about into the next lane to the right. Standard XJ disk and drum set up. Just had brake work about 10 days ago, 400 miles since then and just now happened. Anyone else or any inputs on this?
Thanks
Stay Cool
Mit
Mitmont
XJ 2001 Sport
Mitmont is offline
post #2 of 7 Old 02-13-2013, 07:13 AM
Hudson
Look at the caliper that is opposite to the one pulling.
If it's pulling to the right check the left side brakes.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #3 of 7 Old 02-13-2013, 07:27 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Go back to the place that did your brakes. Have them inspect the work.
CJ7-Tim is offline
post #4 of 7 Old 02-15-2013, 10:49 AM
JWELK
When you grease the rotors to stop the squealing, you have to grease them equally using the same grease. For example, if you use marine grease on the left side and standard grease on the right, and then run through a puddle, the vehicle will pull to the left. Go to any marine parts store and ask for "relative bearing grease". When younger and more daring, I would just grease the right side. You could make awesome "Bat turns" with little effort. Mom usually would ground me, if I forgot to clean it off. It was harder then as you had to pull the drums
JWELK is offline
post #5 of 7 Old 02-15-2013, 11:21 AM
JWELK
My previous post was for entertainment only.
JWELK is offline
post #6 of 7 Old 02-15-2013, 03:40 PM
Azzy
What Tim said... and check your tire pressure. Uneven tires will cause it to pull.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #7 of 7 Old 02-15-2013, 05:12 PM
buildin1XJ
^ what Tim said. Could be that one brake caliper is working well and the other is side is not.
buildin1XJ is offline
