Should we POR15 paint on rear brake drums? Yes or no? - JeepForum.com
post #1 of 7 Old 08-09-2013, 12:58 AM Thread Starter
Charley3
Should we POR15 paint rear brake drums?
My cousin is cleaning and prepping my rusty areas of underbody, frame, drivetrain, and suspension parts before painting them with POR15?
What about rear brake drums? They are very rusty. We'd like to remove them, and prep and paint them with POR15, but we have heat concerns.
How hot do drums gets? (I drive in mountains a lot.)
Would the heat damage the POR15 paint?
Would the POR15 paint be to much of an insulator and cause drums to overheat?
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #2 of 7 Old 08-09-2013, 02:38 AM
dave564
If they are very rusty, they are probably very old. I don't know anything about POR15, matter of fact I had to Google it to see what you were talking about.
The rear brakes make up only about 30% of your stopping force, that is one of the reasons they last so long, unless you are towing. As far as heat I would not sweat it.
HOWEVER they will wear out sooner or later, and will have to be replaced. I personally would not put such an expensive paint on a part that is designed to be sacrificial.
If you are really worried about the looks, invest in new drums, and hit then with cheap spray primer and the color of gloss spray paint you wish.
Durable items like body and suspension components, yes get the good stuff, for brake drums go cheap.
dave564 is offline
post #3 of 7 Old 08-09-2013, 02:50 AM
Holder350
1995 XJ Cherokee
You can prep and paint them with caliper paint and it won't bake off. I've done it on several sets.
They look very nice painted black.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 7 Old 08-09-2013, 07:07 AM
bobthecatkiller
My brake drums are coated with chassis saver. I didn't really care how my drums looked, since I will be upgrading to disc soon but I had extra chassis saver and you can only save it for a few days after its opened.
Anyways it hasn't had any problems and its held up well.
Btw. Chassis saver is chemically the same as por-15
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #5 of 7 Old 08-09-2013, 10:58 AM Thread Starter
Charley3
My drums are 14 years old and very rusty because Jeep from back East (salted roads).
However, it only had 33K miles on it back East and 3K miles on it in the West. So low mileage and I expect will last many more years.
Based on advise from this thread, I'll save them for last and paint them with left over POR15, if there is any. If no POR15 left, I'll rattle can prime and paint them.
I live in a wet climate, but no salt on roads here. So I expect rust won't get worse, if get it under control.
Charley3 is offline
post #6 of 7 Old 08-11-2013, 06:43 AM
Fury3
Will painting the drums force them to retain more heat?
Fury3 is offline
post #7 of 7 Old 08-11-2013, 07:09 AM
bobthecatkiller
I don't know, maybe?
I haven't had a problem. How much braking does the rear brakes do anyways? I don't know much about brakes besides how to replace them, but I'm pretty sure the front brakes do 90% of the work anyways, so how hot can the drums really get?
You can extend gas milage and brake life by coasting when ever you may have to stop, I find most people like to try to gun it to every stop sign and light, it's not always necessary to get up to the speed limit if your not on a main road or highway. This will inevitably keep your brakes cooler, although like iv said, I haven't had a problem with heat.
