Should I drain my transmission fluid? Need opinions - JeepForum.com
post #1 of 5 Old 06-23-2013, 07:39 PM Thread Starter
SteeSin
I've been topping off my Transmission fluid with ATF4 for probably over 2 years, it's been shifting smoothly and havnt had a problem yet but I recently saw that we aren't supposed to use atf4, so I was wondering if I should drain all the fluid out and refill it with dex III, or just keep doing what I've been doing. I'm also afraid to drain the fluid out because I've heard it can be bad to do that because all that old fluid helps keep the trans together and it's been common for peoples trans to break soon after they changed the fluid
SteeSin is offline
post #2 of 5 Old 06-23-2013, 07:44 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Would you use the same engine oil for over 2 years ?
Drain and re-fill with Dexron-III/Mercon fluid as called for in the Owners Manual.
CJ7-Tim is offline
post #3 of 5 Old 06-23-2013, 07:52 PM
biffgnar
biffgnar's Avatar
Last year when I bought my 97 XJ I changed transmission fluid. I am suspicious it had never been changed. AW4 is pretty tough. Still glad I changed it, have had nothing break due to changing and will change more regularly so long as I own it.
biffgnar is offline
post #4 of 5 Old 06-23-2013, 07:57 PM
nixer600
The original fluid is not magical, it can not keep your transmission together, drain fluid and refill according to specs.
Sent from AutoGuide.com Free App
nixer600 is offline
post #5 of 5 Old 06-24-2013, 07:52 AM
wgirvine
1992 XJ Cherokee
Originally Posted by SteeSin View Post
I'm also afraid to drain the fluid out because I've heard it can be bad to do that because all that old fluid helps keep the trans together...
Complete myth. This would be like saying "If you never change your engine oil, the engine will last forever." And if you've been adding trans fluid, it means the tranny has a leak. Fix it.
The road goes on forever, the party never ends....
wgirvine is offline
