Should the compressor be doing this? - JeepForum.com
post #1 of 6 Old 07-25-2013, 08:07 PM Thread Starter
sting7785
I have a 1998 XJ 4.0L Cherokee and I was changing the serpentine belt when I noticed something. I'm not sure if it's supposed to be this way or not. On the AC compressor, the part that the belt is touching (pink arrow) spins constantly as the belt moves. The part in the middle of that (blue arrow) spins for about 3-4 seconds, then stops for 3-4 seconds, and repeats this process. There's a click sound every time it starts to spin. The AC on this Jeep blows, but it's not cold air at all. I'm not sure if this is something that should be normal behavior for the particular part, or if that's an issue. Any input is greatly appreciated. Thank you.
Edit: I apologize for the small image. The site kept making me decrease the size for the upload. ><
sting7785 is offline
post #2 of 6 Old 07-25-2013, 08:12 PM
B52dude
Yes, that is normal. The compressor is just cycling on and off. The blue arrow is an electronic clutch. My 99 TJ does the same thing. But it has icy air.
Edit: To answer the second part of the question, you probably have a leak in the system and have lost pressure, thus no cold air.
Originally Posted by Ripper3494 View Post
i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol
Red Jeep Club #614
B52dude is offline
post #3 of 6 Old 07-25-2013, 08:22 PM
79chiefs
1988 XJ Cherokee
It means your r134 level is low. If it does cycle the clutch it means you have some 134 in it, just get a can and add some. You can get a charge kit most anywhere.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #4 of 6 Old 07-25-2013, 08:46 PM
djb383
Hummm, after our a/c overhaul, the compressor seldom cycles off......and it's cold.
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #5 of 6 Old 07-25-2013, 08:49 PM
Holder350
1995 XJ Cherokee
Probably low on charge. I would take it to someone with a set of gauges to check actual pressures on the system.
Cycling the clutch like that is hard on it and the compressor. I would try to get it looked at soon.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #6 of 6 Old 07-26-2013, 06:50 AM
79chiefs
1988 XJ Cherokee
The compressor should cycle on and off. It is normal, but not every few seconds. If it does not cycle, or cycles every few seconds it means it is low on charge.
95 E34 540i-DD
79chiefs is offline
