Quantcast Should an 1998 XJ stock ele fan be loud??? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Should an 1998 XJ stock ele fan be loud???
Old 05-24-2007, 01:21 PM   #16
DamianDeBe
Originally Posted by L20KEV
mine also comes on about then. What i find funny is mine likes to run at 210, but that only gives it 2* of warming (traffic etc) before the wind turbine starts. I would prefer mine to run at 195 normally so at least i get an extra 5mins piece before it comes on etc
I believe all 4.0s like to run @ 210. That temp assures optimum efficiency and performance. It seems like some fans (and correct me if I'm wrong) kick in at a higher temps. My point is that you actually do have more of a safety cushion than you think. I see it as a good thing that mine pops on @ 212 or so. Helps keep things cool in city traffic.
DamianDeBe is offline   Reply With Quote
Old 05-24-2007, 09:55 PM   #17
tweekedknee
I can just hear mine over my exhaust and intake, not enough to make me nuts but just enough to know its there. Ive never heard it come on without the ac or defrost the 3 row radiator also makes the temp needle rock steady no matter what im doing. Idling intraffic with the ac on in summer it just goes a hair over 210, itsusually a hair under 210.
'97 XJ (here comes the typical list)
3" rustys full pack, Rock Krawler tracbar, 31x10.5 Kumho kl71, CIK, dynomax super turbo muffler, IPF h4 conversions, silverstar bulbs, hella 530 fogs, olympic 4x4 rock front bumper, tcase drop, bush hacker flares, OEM tow hook brackets with GM hooks
tweekedknee is offline   Reply With Quote
Old 05-25-2007, 07:27 AM   #18
L20KEV
Originally Posted by C.Walker
It's a better word for a hood that they use in the UK.
I like it.
And the trunk is the boot.
And if you consider the XJ a wagon, it would be an estate over there.
Your exactly right in what you said (I sometime say either as I watch US films / shows non-stop but the majority say what you described)
Im glad it comes on early like you said, but id just like it a tad quieter.
For the people who have swapped over their viscous fan for an other elec fan...
Which fan have you got and
How quiet is it in comparision to the above.
Thanks for everyones answers
L20KEV is offline   Reply With Quote
Old 05-25-2007, 10:41 AM   #19
toledotimber
Yes, it will be loud (maybe it shouldn't be, but that's something else). Also, the way the fan works is it should cycle on and off when the vents are set to the windshield or windshield/floor combo. The fan actually isn't supposed to come on (without the AC/vents bit just described) unless the temp. reaches 218*. It will then shut off at 209*.
The exact temp. depends on the year. What's above is for a '99, IIRC. A '98 is 217*/208*.
toledotimber is offline   Reply With Quote
Old 05-25-2007, 11:30 AM   #20
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
You would need to fab a pretty large fan in there to not be able to hear it. Due to the small size of the fan blades, surface area, and ammount of air moving through, you are going to hear the air moving quite a bit with that size fan. There isn't much you can do to get around it without removing the mechanical fan and starting to fab an all electric setup.
Kyle - I tag stuff®
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote
Old 05-25-2007, 02:09 PM   #21
wetazz
yup !!
same here my 01 seems loud,but i guess from reading the rest,it's normal.
DEEP IN THE HEART OF DIXIE. (ROLL-TIDE !!)
wetazz is offline   Reply With Quote
Old 05-26-2007, 06:41 AM   #22
L20KEV
cheers, it sounds as if its normal so im happy. Thought id better ask still, coz if everyone else said theirs were quiet i would had classed mine as being on its way out
Old 05-26-2007, 04:22 PM   #23
BrunoS
my gauge will sit at 210'F permanently unless stuck and NOT moving in traffic. That's with a manual transmission. The fan will come on very loud with a/c use or the eventual stuck in traffic hot idle. Comes on around 220 or so, shuts off at 209'F per the manual. However....if creeping in idle and the air can move around the primary fan, then it will cool down rapidly.
for those of you with auto trans, then yes, unless you have an external trans cooler, then your electric "booster" cooling fan will come on a lot more, etc.
the xj has a small radiator for a rather large 4.0L motor, be advised that clean fresh coolant, no more thant 50/50 mix, and good quality 185'F (mopar performance part) or stock 195'F thermostat will do the job.
the xj is designed to run at 210'F for low emissions, long oil life, good gas mileage, and low engine wear. too much beyond either side of that temp can get you into other problems.
most xj's will do fine with the mopar 185'F thermostat, but stick with 5w-30 or 10-30w oil. the 10-40 and 20-50 is wayyyyy too thick at that cooler running motor. be advised that in heavy traffic, that thermostat will be wide open and what you really have is a lack of cooling capacity, and not a "thermostat" restriction issue.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 05-31-2007, 12:44 AM   #24
p2y2r7o
1997 XJ Cherokee
My '97 is just the same. It's my first car, and no one in my family had owned a jeep before...my mom thought it seemed very loud so we took it by the dealership we bought it at and had it checked out. Turned out to be normal, as others here have said!
It doesn't bother me at all. Of course I usually play music pretty loud.
p2y2r7o is offline   Reply With Quote
Old 05-31-2007, 08:19 AM   #25
USN1982
1989 MJ Comanche
heard putting a taurus fan will work. have no clue how that works but my fan is also very loud and dont mind but i live in south texas and it is hot all the time, so hence my fan is on alot as well. looking into a diffrent thermostat or an aftermarket pump or newer electric fan
USN1982 is offline   Reply With Quote
Glock Forum
