Short arm or long arm lift for XJ - JeepForum.com
post #1 of 10 Old 09-18-2008, 10:46 AM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
I'm looking for a larger lift on my '94 Cherokee Sport. It already has a 3 "econo" lift and I'm looking for something along the lines of 4.5 to 5.5 inches of lift, and I can find all kinds, only the prices vary extreme amounts between long arm and short arm lifts... All I'm going to be doing is mostly trail running and very minimal amounts of rock crawling so would there be any real advantage to spending the extra cash for a long arm kit, or should I just save some money and get a short arm?
Thanks.
Originally Posted by Lamb of God
Whoever appeals to the law against his fellow man is either a fool or a coward; whoever cannot take care of himself without that law is both. For wounded man shall say to his assailant, "if I live, I will kill you- if I die, you are forgiven;" such as the rule of honor.
Mr_Clickerson is offline
post #2 of 10 Old 09-18-2008, 10:48 AM
justanotherjpr
At 5.5" on a standard short arm, your ride will suffer. The control arm drop brackets are a great alternative. I love mine, running about 6" of lift.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 10 Old 09-18-2008, 11:03 AM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
Any chance you could link me to a set? I had a notion, and was already informed that the ride would suffer (due to the arms wanting to be pushed back rather than up)... If I do use the drop brackets, would it be as flexible or nearly as flexible as a long arm or am I just asking stupid questions, now?
post #4 of 10 Old 09-18-2008, 11:08 AM
JeepinRU
short arm all the wayget a 4.5 inch lift... more than enough of what your planning on doing... you can make ur jeep 100x better than some mallcrawlers w/ long arms if you put the money into A)new axle B)gears C) lockers
JeepinRU is offline
post #5 of 10 Old 09-18-2008, 11:15 AM
justanotherjpr
My drop brackets flex awesome. Not quite as good as some long arm kits, but I don't get left behind because of it. The Rubicon Express 5.5" kit comes with the drop brackets, IIRC.
http://www.rubiconexpress.com/Produc...=E590417394435
for the kit including the DB's.
just the brackets
braces for the brackets (a must have)
I heard TrailMaster also makes the drop brackets and braces. I bought mine used from another jeeper here on the forum, no problems thus far. Drives great at 85mph!
post #6 of 10 Old 09-18-2008, 11:18 AM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
Thanks for the quick replies guys- I guess the way to go is the short arm kit... At my local 4x4 supplier (not really local, but not too terribly far away), they have a Rubicon Express 5.5 inch complete set including drop brackets... And at 1,500 bucks doesn't sound too bad...
About lockers, though- I heard ARB has some nice lockers. Can anyone confirm this?
post #7 of 10 Old 09-18-2008, 11:25 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
http://www.roughcountry.com/jeep_xj_4.html#winch These are a lot cheaper than the RE's
xjfever is offline
post #8 of 10 Old 09-18-2008, 12:01 PM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
Thanks, xjfever, but that doesn't really seem to be on the same level of quality though yes, it is much cheaper. I think I'll stick with the Rubicon as my choice.
post #9 of 10 Old 09-18-2008, 12:22 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Sounds like you've already made your decision (a good one), but to answer this question in particular -- it really depends on everything else in the suspension. For example, if you compare the RE 5.5" short arm kit with the DBs vs the RE long-arm kit, both will flex the same amount. This is because the only difference in the kits is the arms, and the arms aren't the limiting factor for those kits -- the shocks and trackbar are. Long-arms have the potential for greater wheel travel though, if you change up other parts of the suspension.
Check with that local supplier to see if you're getting any shocks with the kit at that price.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #10 of 10 Old 09-18-2008, 01:13 PM
justanotherjpr
Chances are good that your local supplier will charge more. Most of us buy online. I have had good experiences with Chris at offroadtoystore.com. The give free Rubicon twintubes with every lift kit, and used to do free shipping as well (they probably still do). It's worth your time to call around. Also, in most states you can still avoid the tax by buying on-line.
I've heard nothing but good things about Jeepin.com, but have never purchased anything there myself.
With my drop brackets and 33's, I have more than enough wheel travel.
Long bed -> Short bed phokur MJ Comanche Technical Forum 4 01-17-2009 02:11 AM
Long vs. Short AAL & other ?s dudeinajp XJ Cherokee Technical Forum 5 06-30-2006 11:25 PM
Short arm vs long arm 1badxj XJ Cherokee Technical Forum 18 10-30-2005 09:51 AM
4 1/2 Inch Lift Short or Long arms CanadianCook XJ Cherokee Technical Forum 1 06-22-2005 12:18 AM
Short or Long AAL bdw8 XJ Cherokee Technical Forum 5 08-16-2003 12:13 AM
