Shop wants $163.00 to change an o2 sensor part included - JeepForum.com
post #1 of 17 Old 12-09-2009, 11:34 AM Thread Starter
ARgetni
2014 WK
The part cost for me is $33 o2 sensor (Walker 250-24078) from amazon plus $17 for the o2 sensor socket set from amazon as well.
I think the sensor on the car is original so it has 10 years and 160k of rust, but I hate to pay 3x for something I can do myself.
My car maintenance experience so far is limited to oil changes, air intakes, boost gaugues, FPRs, shocks, and struts/springs.
I think I can handle this. but I do hesitate a bit.
ARgetni is offline
post #2 of 17 Old 12-09-2009, 11:41 AM
Motorcharge
It's not even an hours worth of work, thats absurd. It's a very easy swap, it's right on the exhaust by the motor. If you have a deep socket set you might not even need the sensor socket. Even if you do every major parts store carries them.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 17 Old 12-09-2009, 11:51 AM
bmyohn
Youngin'
bmyohn's Avatar
x2 even if you do have to go out and grab a 02 sensor socket it shouldnt be that bad. the XJs witht he pre-cats can be kind of tricky to get to sometimes, but is extremely do-able with basic hand tools
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #4 of 17 Old 12-09-2009, 11:51 AM
dcorn
Dude. The O2 sensor has one plug on it and unscrews with a normal open ended wrench or box wrench. It will take 5 minutes to change... if you are drinking a beer at the same time.
Judging by your previous experience, I'm thinking you had a WRX before the Jeep...
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #5 of 17 Old 12-09-2009, 11:52 AM
XJohnnyC
XJohnnyC's Avatar
It's a ten minute job. One connector to undo. And I just use a crescent wrench to take the sensor off. But since you guys do get more rust out there, soak the threads with PB Blaster.
XJohnnyC is offline
post #6 of 17 Old 12-10-2009, 12:41 AM
isha0018
1997 XJ Cherokee
is it up frar enough from the road that it doesnt get any thing on it? My full size bronco with the socket and torch sucked to get off and on for that matter. I ended up welding another bung... then it was easy. I havent looked at the location of my o2 sensor yet.
isha0018 is offline
post #7 of 17 Old 12-10-2009, 05:24 AM
munroejp
Just did mine a week ago.
Let the exhaust heat up and use an open end wrench.
Took 10 minutes.
munroejp is offline
post #8 of 17 Old 12-10-2009, 05:57 AM
kboyts
mot parts stores will "loan a tool" you an o2 socket for free. (give them a deposit then they refund it all when you return the tool.)
=====_____
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
kboyts is offline
post #9 of 17 Old 12-10-2009, 06:08 AM
xjokee
I bought an O2 removal socket. It's been a great investment. I've used it three times in two years. It's def easier than an open end wrench,especially if there's a rust issue, and maybe a 15 min or half beer job. Once changed, do yourself a favor and use anti-seize on the threads of the new sensor. Just don't slobber it up all over the element itself.
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #10 of 17 Old 12-10-2009, 08:14 AM
Lupitaboy
You may very well be overqualified to change out your O2 sensor.
96 w/ 5spd, 4.10s w/ lsd, Bastard Packs, armor/ rack, BFGs & JK Blacks
Lupitaboy is offline
post #11 of 17 Old 12-10-2009, 01:05 PM
keepishop
1989 XJ Cherokee
It's hard to find, and hard to get your hands on, but once you've got that out of the way the actual swap is a piece of cake. Took me about an hour in a parking lot, and most of that was searching for the little #$%.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #12 of 17 Old 12-10-2009, 01:30 PM
justin302
I had an o2 sensor go bad, so I went to the junk yard and picked one up for a whole dollar.It took 5 minutes to change out the sensor (cresent wrench) and walla no problems. Yes I know JUNK YARDING for an electrical sensor!!!, well it fixed it and it runs like a top now, so if I was wrong and the sensor was a dud, oh no a whole dollar!!! Yes I am cheap, but at least I still have beer money!!
justin302 is offline
post #13 of 17 Old 12-10-2009, 01:42 PM
89xjchris
?????????? i hope it was dark cuz if you get on your back under the drivers door its in your face.\
it didnt even take me an hour for my cps sensor??.
Originally Posted by millhousenator View Post
can we just keep our ****ing comments to ourselves about whats a jeep and what isnt. Whether you like it or not its a jeep and he's on jeepforum. Jeeps are like boobs, some are big, some are small, some look fake and some look real, but they are still boobs so get the **** over it!
Originally Posted by bradyman1 View Post
Use duct tape. That always quiets the lady's down when they start kicking and screaming.
Originally Posted by Hunterdad View Post
And remember, anything that is camo is not gay.
89xjchris is offline
post #14 of 17 Old 12-10-2009, 02:12 PM Thread Starter
ARgetni
2014 WK
The sensor I need to replace is the one After the cat. Before I replace it i will check the fuse I read about in another thread. That may be what is causing the P0138 code.
ARgetni is offline
post #15 of 17 Old 12-10-2009, 02:46 PM
keepishop
1989 XJ Cherokee
I was the day I bought the jeep, so it all just looked like a jumble of pipes and wires to me.
Bleed or Quit.
transmission repair shop says to never change trany oil comet605 XJ Cherokee Technical Forum 33 08-17-2009 07:03 PM
When to change O2 sensor? sw19 XJ Cherokee Technical Forum 8 05-08-2006 07:21 AM
Need help identifying a part (pic included) fourlow XJ Cherokee Technical Forum 6 01-25-2006 06:05 PM
What the shop wants to change my exhaust. 92XJMuddin XJ Cherokee Technical Forum 5 12-23-2005 12:44 PM
O2 Sensor Change 96ironman XJ Cherokee Technical Forum 8 11-26-2003 10:24 PM
