Shocks - JeepForum.com
post #1 of 2 Old 07-11-2013, 11:01 PM Thread Starter
timheff
Shocks
Any one know the dimension of front shocks that I'd need for a 4.5 lift in a 92 and recommend a good set
timheff is offline
post #2 of 2 Old 07-11-2013, 11:39 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Bilstein
Fox
Old Man Emu
Sway-a-way
King
Are all excellent brands that make awesome shocks I personally have run Bilsteins on Everything I've Lifted
There are tons of threads on this subject , Don't be afraid to use the search feature !
Since I am in a good mood here is your answer :
The easiest way to measure the shock lengths is take your old ones off and fully cycle the front suspension, Measure the distance of the compressed side and the extended side, Then do the same thing with your Rear, Go online or to your local offroad shop and Buy shocks that fit those Extended/compression stats. Be Warned Good shocks will set you back $325.00 and Up for all 4, If it has a painted body (Other then the Old Man Emu ) it is not worth spending money on.
And welcome to JF
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
