Quantcast Shock bolt replacement: a fix with pics (Heavy) - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Shock bolt replacement: a fix with pics (Heavy)
Old 02-20-2009, 04:45 PM   #61
LobstahJeep
1995 XJ Cherokee
Originally Posted by Moogie View Post
Same idea, only took less time.
I used my hole saw to cut two holes in the floor, directly above the top of the shocks.
So I should have no problems then?
95 XJ Sport - The Lobstah
01 XJ Sport - The ZEEP!
LobstahJeep is offline   Reply With Quote
Old 02-27-2009, 09:18 PM   #62
Absolutexero
Originally Posted by Determined2Rise View Post
What is a BFE???
its a combination of a BFH and a BPE
it's the ultimate cherokee modification tool a Big F***ing Eliminator
AKA - an angle grinder
Current: 1998 Cherokee Classic (White)
stock with 263k miles yay!
SOLD 1999 Cherokee Sport (Black)
~6" Franken-lift (2" CSS/ Rusty's 180lb 3" front springs, S10 bastard pack w/ 3" Rusty's AAL)
Absolutexero is offline   Reply With Quote
Old 02-27-2009, 11:28 PM   #63
dajeepman
no no this is a BPE
I had a friend weld them up in place where the shock would bolt to.. works just fine.
1998 Jeep Cherokee Sport 4x4
173K miles 3'' Budget Boost
31x10.50x15 Dakota MT
C4x4 Winch Bumper Warn XD9000I
D30 Aussie Locked Chry 8.25 open
TNT Belly Pan installed TNT Long Arm Kit ( Soon to be installed )
dajeepman is offline   Reply With Quote
Old 04-10-2009, 10:17 PM   #64
Fox Fader
Glad I found this, I broke 2 today as one was already. Broke some cheap removal tool too. I'll get the chissle out in the morning at fix this... I was going to get em tack welded.
God Rules!
Fox Fader is offline   Reply With Quote
Old 04-10-2009, 10:41 PM   #65
Lew360
1992 XJ Cherokee
How much for the 03 RSV.
Lew360 is offline   Reply With Quote
Old 04-11-2009, 09:57 PM   #66
Fox Fader
http://atlanta.craigslist.org/mcy/1118201455.html
Unbelieveable how easy this was, and I spent hours trying to extract those broken bolts. Got grade 8 and anti-seized all, still got on good OE bolt up there.
God Rules!
Old 04-12-2009, 06:19 PM   #67
jaymartin
I broke mine off too. Knocked the bolts out and made this little doodad up. You can feed the bolts through in about 5 minutes. Some washers for support and tighten everything up. Whole job about 20 minutes.
Coat hanger wire, string and a slip knot.
2000 XJ 4X4 SPORT, 2" RE BB, 30x9.5 BFG KM2's
|lllll|
jaymartin is offline   Reply With Quote
Old 04-13-2009, 10:24 PM   #68
Fox Fader
I used some weed trimmer line and some masking tape.
God Rules!
Old 04-14-2009, 10:50 PM   #69
GregB_00XJ
GregB_00XJ's Avatar
Just got these in the mail yesterday... Thanks Quadratec.
Even though I have new hardware installed, these make me feel better!
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 04-15-2009, 07:58 AM   #70
SkinnyMe97
1997 XJ Cherokee
Hate to be a downer but those BPE's suck , they set your bushing 90 deg. from where they need to be to work properly !
SkinnyMe97 is offline   Reply With Quote
Old 04-15-2009, 11:46 AM   #71
Jon08JK
Jon
Jon08JK's Avatar
I am confused. Those BPE's are used on the rear shock upper mounts? This thread is about breaking bolts on the rear upper shock mounts right? I'm not being a smart ***, I really don't know.
2008 Sahara Auto 2 Door 20,450 miles JKUR Coils and shocks, Magnaflow, Superchip, Banks CAI, Winch, OBA and 4:88's
Jon08JK is offline   Reply With Quote
Old 06-03-2009, 07:55 PM   #72
PSUxjJeeper
did this today worked great. snapped off 3 of them putting my lift in. i could actually reach all the way up with my fingers. so it was a snap.
i used to study then i found jeep forum...
PSUxjJeeper is offline   Reply With Quote
Old 06-04-2009, 12:34 AM   #73
GregB_00XJ
GregB_00XJ's Avatar
Yes...you are correct. BPE's are to replace the upper rear and lower shock mount bolts and the bar pin with what you see in the picture.
See below (front and rear BPE's installed):
Front:
Rear:
____=__=
l l ,[_____],
()_) ()_)--o-)_)
Old 06-04-2009, 11:55 AM   #74
XJ99
K I S W
XJ99's Avatar
Front:
Rear:
Those look like rear sway bar mounts.. They are mounted wrong,
and don't allow the top of the shock to pivot in the right direction.
Take them off, give them a 1/4 turn, and weld them in to place..
The wrong way....
The right way...
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline   Reply With Quote
Old 06-04-2009, 07:34 PM   #75
Crunch
The wrong way....
The right way...
What kind of BPE's are those?(the correct ones)
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering
Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift.
SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it!
Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff.
Crunch is offline   Reply With Quote
Glock Forum
