| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack (2) | Thread Tools |
#31 | ||
#32 |
Man, where were you when I needed you!
99 Sport, 3.5" RE front coils and Quadratech HD rear leafs with RE AAL, Rusty's shocks. Rusty's Sway Bar disconnects. RE HD ADJ Track Bar. RE Hack n Tap SYE. 31" BFG ATs on 15x8 (4.5"bs) procomp rockcrawlers. 2.5" Gibson Catback. C4x4 Tow Hooks. Rear Diff Guard. Warn Front Diff Guard and TC Skid. Yakima rack. Cobra CB. AJ's Rocker Guards. JCR Stage 1 rear bumper. JCR Stage 4 front bumper. ORE front steering box brace. |
#33 |
forum supporter
I can't believe anyone would cut a hole in the floor, when the method above took me 30 minutes. I installed BPE's with grade 8 bolts, and never have to mess with them again.
#34 |
I installed a set of Edelbrock IAS shocks on Saturday. It turned in to a 2 1/2 hr job with the broken off bolts. I elected to drill out and retap. The time eater was the fact my Milwaukee keyless chuck kept letting the drill bits slip and I was using less than premium bits in at least grade 5 bolts. I finally got thru and used 5/16" x 18 Stainless bolts with marine grade anti seize.
#35 |
If you have a welder, I'd opt to do the easiest method out there:
Weld the stock sway bar U-bolt plate brackets in place of the bar pin bolt bull ****. If the shocks you have incorporate the factory bar bin, simply pick up some poly shock bushings from any auto parts store and a 1/2" metal sleeve from any hardware store. Total mod time: 15 minutes and roughly $5.00. git er done.
99 chilipepper red XJ: Race car tow rig. Turbo project in the works. Head of Core production - www.CortekSystems.com Owner of Boostwerks.com Website in development. |
#36 |
Awesome
Great write up and pics! I was literally just about to go down and drill thru my floor to fix this problem...Thank you for the many great sticky's!
You guys rock! |
#37 |
Same idea, only took less time.
I used my hole saw to cut two holes in the floor, directly above the top of the shocks. ![]() You could remove the carpet but i couldn't be arsed ! ![]() Soak the top of the bolts thoroughly with WD40 or similar. When you go to remove them, give them a slight tighten first. I managed to get all four out with no trouble at all. Total time, 10-15 minutes. |
#38 |
here is what i did. been in service a year an 20,000 miles, holding up great. by the way i used the stock holes from underneath.
99xj, 4.0, aw4, nv 231 d-30, 8.25. dessert sand pearl. former rent a car from Enterprise. great shape! 06 kj 3.7l, 6speed manual, np241 command track 91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers Last edited by x99j; 04-11-2009 at 08:54 AM. |
#39 |
That carpet took me a whole 5 minutes to pop out. Hardest part was those d rings. Didnt even need to remove the plastic trim as the carpet just tucks under.
I only read the pictures. |
#40 | |
#41 | |
![]() Very nice write-up xtreme ![]()
'98 xj: 3.5" RE, 31's, nates front bumper, etc etc... '90 xj: Wrecked, waiting for the day it can become a full blown trail rig. '00 wj SOLD (still in family) |
#42 | |
dakuda is a god
however, i have done it the way the OP did it on at least 3 other jeeps and that way works MUCH better...
SOUTH WEST MICHIGAN JEEPERS!!!!! CLICK HERE TO JOIN NOW!!!!
#43 |
This is deff the way to do it and is very, very common sense solution. Doing it the red neck way is NOT the way to do it and i dont see how people dont find it a problem cutting holes in the floor. I guess i just dont like things looking tacky and will spend the little exta time that is required do make it look rite and function correctly.
x99j do you do any wheeling with your jeep? It's just that all the strain is on the floor and not the mounts when the shock is pulling down that would make me scared. Pushing up the strength its just the same. Just under heavy wheeling conditions might wonder if the floor would cave in?
IVE GOT THE BUG! 99 XJ 4.5 RE lift, 33 bf-muds, Homemade Roof Rack with Tire Mount |
#44 | |
dakuda is a god
#45 | |
99xj, 4.0, aw4, nv 231 d-30, 8.25. dessert sand pearl. former rent a car from Enterprise. great shape! 06 kj 3.7l, 6speed manual, np241 command track 91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Shock Bolt sizes? | 1996BlackXJ | Cherokee Technical Forum | 2 | 11-15-2008 12:04 PM |
| Broken shock bolt | XJmaniac | Cherokee Technical Forum | 10 | 08-29-2008 01:38 PM |
| only broke 1 top shock bolt... now i need to get it out | jersey_jim | Cherokee Technical Forum | 10 | 09-03-2007 07:53 AM |
| HELP broken shock bolt | ohioxj | Cherokee Technical Forum | 13 | 11-25-2006 11:03 PM |
| need shock bolt sizes | mk20rockeye | Cherokee Technical Forum | 1 | 10-20-2006 02:00 PM |
The time now is 02:40 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
