To Shim or not to Shim...D35 to 8.25 - JeepForum.com
post #1 of 7 Old 02-06-2013, 07:40 AM Thread Starter
Mikes96XJ88FSB
Hey everyone, Have a couple questions. I bought this 96 XJ a couple weeks ago. My first Jeep, And so far I really dig it. The PO put alot of work and care into it. But it still has the D35...3.55 open carrier. No lift other than AALs, and running 30X9.50s. When he had the AALs installed, He had it shimmed 3 degrees...And I think also did a 1 inch tcase drop to still run the slip yoke. I will check the paperwork to confirm on the tcase drop.
My main question is, I plan to swap to the 8.25, So will I still need to A: shim the 8.25, and B: If I have to shim, Will I be ok to use the ones that I have now for the D35? Thanks ahead of time!
-Mike- 96 XJ Country: 4.0 HO, Auto, 3.55s, D30/8.25, 30X9.50s, Armored, Mopar Header, Glasspack, Custom Stereo, Roof Rack, 3in RC & 2in Blocks.
88 Bronco XLT: #'s Matching with 58k miles, Built Windsor making north of 440hp, C6, 4.10s, 31X10.50s. Factory Quad shock.
Mikes96XJ88FSB is offline
post #2 of 7 Old 02-06-2013, 08:02 AM
DNFJ
3 degree shims and a 1 inch tcase drop on... no lift? You wouldn't need either.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #3 of 7 Old 02-06-2013, 08:32 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
How much lift on the Add a Leafs? 1"? Phfister is right. You shouldnt have any issues up to 2 1/2". When you swap axles, pull those shims and remove the t-case drop.
Randonexplosion is online now
post #4 of 7 Old 02-06-2013, 09:02 AM Thread Starter
Mikes96XJ88FSB
Shoot, I'm sorry I forgot that somewhat important info. Yes its a stock lift. I assume they are only 1 inch. As they were only to rid of the typical sag in the stock leafs. I wasn't really planning on going over 2.5 inches of lift anyway.
post #5 of 7 Old 02-06-2013, 09:09 AM Thread Starter
Mikes96XJ88FSB
Here's a picture of it for reference.
post #6 of 7 Old 02-06-2013, 09:20 AM
DNFJ
That's a sharp looking XJ!
But yeah, no TC drop or shims needed.
Previous:
DNFJ is offline
post #7 of 7 Old 02-06-2013, 09:27 AM Thread Starter
Mikes96XJ88FSB
Thanks! I appriciate it, When I seen it, I couldn't believe it. When I drove it, I fell in love with it. Funny thing, I used to prefer the ZJ/WJs...No more! Anyway, thanks for the advice. I'll be sure to update when I go to do the swap.
8.25 , axle , d35 , swap , xj
