Shifter Cable Stretched?? - JeepForum.com
post #1 of 5 Old 08-01-2010, 08:27 AM Thread Starter
fishermanfloyd
1997 XJ Cherokee
My gear shift no longer lines up with the selector positions next to the gear shift. I also cant even select the 1-2 position as well.
I have tried adjusting the cable 3 separate times according the procedure in the FSM. Each time the results yield nothing to correct the problem.
Is it safe to say that I need to replace the shifter cable
, or am I missing something?
Originally Posted by afbond03 View Post
I am trimmed and hope to get a pair one day.
fishermanfloyd is offline
post #2 of 5 Old 08-01-2010, 08:31 AM
4jeepers
We would have to see a pic. However I used washer spacers on mine, but mine was only off around a 1/4 inch. Either way the cable is not very expensive!
4jeepers is offline
post #3 of 5 Old 08-01-2010, 08:55 AM Thread Starter
fishermanfloyd
1997 XJ Cherokee
I guess I could take a pic, but my description is spot on.
post #4 of 5 Old 08-01-2010, 04:04 PM Thread Starter
fishermanfloyd
1997 XJ Cherokee
Fixed it, my cable bracket was bent away from the bell housing putting the cable in a bind. Pried it back and then I had to use 2 washers on each bolt to get the 1/8" I needed to get to park. Problem solved. Thanks.
post #5 of 5 Old 08-01-2010, 05:14 PM
4jeepers
Good!
4jeepers is offline
xj 4x4 lever, stretched linkage maybe? gonejeepin04220 XJ Cherokee Technical Forum 12 01-26-2013 02:31 PM
shifter cable problems aw4 mr_imposible XJ Cherokee Technical Forum 4 08-01-2010 10:14 AM
Has anyone stretched a Cherokee? tagaiz XJ/MJ Cherokee Non-Technical Forum 5 06-21-2009 10:53 AM
auto shifter cable(s) ? bustednuckles XJ Cherokee Technical Forum 1 02-12-2009 07:24 PM
Stretched Jeep Paybac XJ Cherokee Technical Forum 16 04-08-2008 06:11 PM
