-   -   Shifter Cable Stretched?? (http://www.jeepforum.com/forum/f11/shifter-cable-stretched-1080585/)
fishermanfloyd 08-01-2010 08:27 AM
My gear shift no longer lines up with the selector positions next to the gear shift. I also cant even select the 1-2 position as well.
I have tried adjusting the cable 3 separate times according the procedure in the FSM. Each time the results yield nothing to correct the problem.
Is it safe to say that I need to replace the shifter cable
, or am I missing something?
4jeepers 08-01-2010 08:31 AM
We would have to see a pic. However I used washer spacers on mine, but mine was only off around a 1/4 inch. Either way the cable is not very expensive!
fishermanfloyd 08-01-2010 08:55 AM
I guess I could take a pic, but my description is spot on.
fishermanfloyd 08-01-2010 04:04 PM
Fixed it, my cable bracket was bent away from the bell housing putting the cable in a bind. Pried it back and then I had to use 2 washers on each bolt to get the 1/8" I needed to get to park. Problem solved. Thanks.
4jeepers 08-01-2010 05:14 PM
:cheers2: Good! :thumbsup:
The time now is 12:43 AM.
