Shift Indicator Light on in top gear, ax15 trans - JeepForum.com
post #1 of 4 Old 07-08-2017, 07:05 PM Thread Starter
Putput37
Xj Shift Indicator Light on in top gear, ax15 trans
I recently had my XJ's tranny rebuilt. since then, my upshift indicator light will come on randomly in top gear, and my speedometer bounces slightly +-10 mph.
Anybody know anything about this problem?
Putput37 is offline
post #2 of 4 Old 07-10-2017, 12:56 PM
COMTB
1989 XJ Cherokee
Fairly common, happens in my 1989 XJ and in my TJ one with the puegot trans one with the ax15 I think it's just how it senses when it's time to shift.
1989 XJ Build:
COMTB is offline
post #3 of 4 Old 07-10-2017, 03:46 PM
YY5RM
1988 MJ Comanche
Hello Engineer Putput37, nice to meet you and for my part welcome.
I recommend to indicate the Jeep model and year to be able to help you better.
On Jeep models like that of our colleague Comtv the SHIF indicator depends on the engine RPM and the indication of the speedometer is not electric, it is mechanical, in this case it may be a bad coupling of the plastic gear located at the exit of the AX15.
On page # 7 of the following file is a photograph of the plastic gear.
https://files.acrobat.com/a/preview/...9-3f543126a5db
Regards.
QRV.
YY5RM is offline
post #4 of 4 Old 07-14-2017, 01:32 PM Thread Starter
Putput37
Thanks, I got it all sorted out. Good info though.
Putput37 is offline
