She has died. - Page 2 - JeepForum.com
post #16 of 18 Old 10-04-2010, 07:14 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by dukie564 View Post
fluctuating rpms can also be caused by a vacuum leak to the manifold. Check all your vacuum hoses for leaks or disconnections
Good advice as we have shifted gears from a stall/no-start to an idle issue. with the engine cold, snug up the intake manifold bolts working froom the center outward. Also spray some oxygen sensor safr throttle body cleaner around area that could have vacuum leaks. Idle will change when you hit them. BTW, ever cleaned the throttle body and idle air controller? Good place to start and it's preventative maintenance anyway.
cruiser54 is offline
post #17 of 18 Old 10-04-2010, 11:48 AM Thread Starter
Sergeant_Zeta
1991 XJ Cherokee
Well I think it was the sensor connection. I fiddled around with it some more and it has given me no more trouble.
Sergeant_Zeta is offline
post #18 of 18 Old 10-04-2010, 11:50 AM Thread Starter
Sergeant_Zeta
1991 XJ Cherokee
But thanks for ALL of the tips!
dead , start problems , starting issue , xj
It just died Hunterdude XJ Cherokee Technical Forum 3 07-05-2009 08:57 PM
She died... 88XJSport XJ Cherokee Technical Forum 13 03-07-2008 07:24 AM
almost died? surryjeepin XJ Cherokee Technical Forum 4 04-08-2007 09:41 PM
It died AGAIN! Cheap_JEEP88 XJ Cherokee Technical Forum 8 09-25-2006 10:22 PM
XJ died saxj XJ Cherokee Technical Forum 11 12-07-2005 05:10 PM
