She has died. - JeepForum.com
post #1 of 18 Old 10-01-2010, 11:11 PM Thread Starter
Sergeant_Zeta
1991 XJ Cherokee
She has died.
My 1991 Laredo XJ just died on me tonight. I was cruising home after work going ~40mph when the engine just quit. Pulled over and tried and tried and tried. Nothing. So now she's sitting there all alone in the cold night.
I have had a few stalls before, but never while the RPMs were up in normal running range before. Also, she's always come back to me in the past no problem. So, I was wondering if any of you kind folks would have any ideas before I have to call the wrecker and take her to a mechanic. Absolutely any help would be appreciated.
Sergeant_Zeta is offline
post #2 of 18 Old 10-02-2010, 12:17 AM
RBxj
Try unplugging the cps and reconnect. Might take two or three times, they sometimes get loose and corroded after a few years.
RB
RBxj is offline
post #3 of 18 Old 10-02-2010, 08:20 AM
dukie564
1995 XJ Cherokee
Your issue is most likely a bad Crankshaft Position Sensor (CPS). It's a very common problem on our vehicles, and causes the engine to just shut off as your describe.
Does it try to start (does it crank?) or is there no activity whatsoever when you turn the key.
If there is nothing happening i would look at a loose battery connection as the culprit.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #4 of 18 Old 10-02-2010, 08:37 AM Thread Starter
Sergeant_Zeta
1991 XJ Cherokee
Thank you both so much. It seems it was the connection for the cps. I love you guys.
post #5 of 18 Old 10-02-2010, 08:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's a hint and you just verified it for yourself. Unplug every sensor in your engine compartment one at a time, flush the connectors with a good contact cleaner and plug them back in. Guards against future problems. 15 minute job and worth it.
cruiser54 is offline
post #6 of 18 Old 10-02-2010, 09:03 AM
dukie564
1995 XJ Cherokee
I love you too...
dukie564 is offline
post #7 of 18 Old 10-02-2010, 11:17 AM Thread Starter
Sergeant_Zeta
1991 XJ Cherokee
Well, it appears the battle is not over. Now it starts every time... but the rpms jump around occasionally and she will stall out. Sometimes it will start again on its own, other times I have to put her in neutral and crank her up.
post #8 of 18 Old 10-02-2010, 11:48 AM
1moneypitt
1991 XJ Cherokee
throttle position sensor most likely culprit for the sporadic rpm's. if you have to put it in neutral to get it to start sometimes, have someone verify your backup lights work. if not i will pretty much guarantee that your neutral safety switch needs to be cleaned and greased.
1moneypitt is offline
post #9 of 18 Old 10-02-2010, 12:10 PM
Jackup
Originally Posted by dukie564 View Post
I love you too...
Jackup is offline
post #10 of 18 Old 10-02-2010, 07:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See post #5 before proceeding any further. No joke.
post #11 of 18 Old 10-02-2010, 11:21 PM Thread Starter
Sergeant_Zeta
1991 XJ Cherokee
Thanks cruiser, i'll do that. Would you suggest some kind of silicon contact stuff as well? I think I've heard of that helping.
post #12 of 18 Old 10-03-2010, 07:08 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Dielectric grease is good to use. It helps guard against future corrosion.
post #13 of 18 Old 10-03-2010, 07:12 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Same stuff you'll want to have around when you service your NSS anyway. When doing the unplugging and cleaning don't forget the two connectors going to the trans. They're between the right rear corner of the engine and the firewall. One big gray one and one big black one. Mine were filthy.
post #14 of 18 Old 10-03-2010, 08:34 PM
rondak46
possibly a clogged catalytic convertor?
rondak46 is offline
post #15 of 18 Old 10-04-2010, 06:55 AM
dukie564
1995 XJ Cherokee
fluctuating rpms can also be caused by a vacuum leak to the manifold. Check all your vacuum hoses for leaks or disconnections
dukie564 is offline
dead , start problems , starting issue , xj
It just died Hunterdude XJ Cherokee Technical Forum 3 07-05-2009 08:57 PM
She died... 88XJSport XJ Cherokee Technical Forum 13 03-07-2008 07:24 AM
almost died? surryjeepin XJ Cherokee Technical Forum 4 04-08-2007 09:41 PM
It died AGAIN! Cheap_JEEP88 XJ Cherokee Technical Forum 8 09-25-2006 10:22 PM
XJ died saxj XJ Cherokee Technical Forum 11 12-07-2005 05:10 PM
