Quantcast shakking ahhhhhh - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > shakking ahhhhhh
Genuine Italian leather shift boots for your Jeep!Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 07-09-2007, 08:13 PM   #1
vtjeeps
shakking ahhhhhh
ok wife got home told me jeep shakes after she hits a bump . i have never worked on a xj so any ideas?
vtjeeps is offline   Reply With Quote
Old 07-09-2007, 09:04 PM   #2
dopod
search "death wobble". You will get about 104868493 threads on it. There is no sure fire answer. You have to find what is loose up front. Could be bushings, loose bolts, bent/broken/lose trac bar/tie rod/control arms.....You get the idea.
dopod is offline   Reply With Quote
Old 07-09-2007, 09:14 PM   #3
BlkBird
Well I randomly selected 2000 as the year for your Cherokee since you did'nt bother to tell us. There is a TSB for that 02-003-03 AUG 03 Steering/Suspension - Shimmy After Hitting a Bump you might want to look into.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline   Reply With Quote
Old 07-09-2007, 09:20 PM   #4
sharpie
German car snob
sharpie's Avatar
1999
uhh, it's probably not death wobble, it's probably bump steer. Check your tie rod ends and your steering stabilizer. I had this a month ago and put on an OME stabilizer from Jeepinoutfitters.com and it works fine now.
- Brian
Klein Concept and Design
KCD Website
Follow us on Facebook!
XJ Writeups:
| DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE
sharpie is offline   Reply With Quote
Old 07-10-2007, 02:52 AM   #5
NinjaofDoom
1990 XJ Cherokee
where can i buy bushings for my track bar?
There was the episode where I threw my shoe at the enemy, like this!.... my foots cold.
NinjaofDoom is offline   Reply With Quote
Old 07-10-2007, 04:37 AM   #6
Spenzin
Had this happen to my XJ a while ago before the lift and definitely not DW but very annoying. Make sure the tires are balanced first. I had one tire out of wack and after getting it balanced never happened again. If that doesnt fix it then I would start checking all of the other parts people posted.
2000 XJ Sport 4.0 L - 4.5 inch mixed lift, 33" Dunlop Mud Rovers, trimmed, Hack and tap in not so distant future.
Spenzin is offline   Reply With Quote
Old 07-10-2007, 05:26 AM   #7
_Cody_
1993 XJ Cherokee
A little off topic, but a jeep newb here...what technically is death wobble?
2002 Trans Am WS6 ~Shop Car. 396ci, LS3 heads, Turbonetics 78mm, NX express, full 10pt cage...it's fast-ish.
2000 Grand Prix GTP ~Ported, Pullied, Heads, Cam, and all that jazz.
1996 XJ Sport. 4.0/A4 Daily Driver. 4.7 stroker and 3.5" lift in the works.
_Cody_ is offline   Reply With Quote
Old 07-10-2007, 05:40 AM   #8
vtjeeps
hey u gess rite
it is a 2000 xj good job..lol
Old 07-10-2007, 07:13 AM   #9
conrasm
Severe shaking of front end usually at highway or near highway speeds that gets better when you slow down. Can be caused by one or both tires moving or the entire axle shifting back and forth. The entire front end shakes and you think the truck is going to fall apart. It's usually caused by loose steering components (tie rod ends, loose steering box), worn track bar ball joint or loose mount of frame side or rounded out hole on axle side, worn ball joints, or worn out bushings in control arms.
It helps to have someone turn the front wheel while you inspect front end parts for movement. It's always a good idea to have the tires balanced and get a front end alignment. Unfortunately, there's not one thing that causes it, so it's more of a trouble shooting thing.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Old 07-10-2007, 07:36 AM   #10
_Cody_
1993 XJ Cherokee
ah...I get it now...Thanks!
Old 07-10-2007, 06:10 PM   #11
vtjeeps
aaaaaahhhhhhhh haaaaa
ok check front end universals very bad..
Glock Forum
