a couple options...
try and bend it which prob. wont work considering its all rusted.
try and move the mounting bracket on the muffler or bend the hanger.
odds are your gonna have to cut off the muffler tip.
thats what mine looks like too. what does it really matter? its not hurting anything is it? im just cutting it all out and getting a turndown out of the muffler. another option if it is killing you so bad.
I suppose it's the noise generated which makes it annoying. As said, try to bend the end, or if it doesn't work cut it and isntall a turndown end to the pipe.
Same problem here, I tried to bend the pipe with no luck so I decided to isolate the pipe from the shackle bolt. I went to the local pick and pull junk yard and just pulled an assortment of different rubber bump pads from an assortment of different vehicles. Mini van or SUV rear liftgate seem to have the best ones. I moved the pipe enough to put the rubber piece on the end of the bolt, once this is done the pipe holds it on. It works great, stops the rattle on start up and the vibration while driving. I got about seven different ones for like $2.00 so now I have some spares if they fall off.
Along with the above mentioned solutions, you might try installing the lower shackle bolt so that the nut is on the outside of the shackle, opposite the tailpipe.
Just deal with it. When it gets moved over and into the shackle, just insert your jack handle into the exhaust and move it back down. I have to do this about every trip out, but it only takes a second or two anyway.
Ha. I had just lopped mine off too. Then on a road trip, the exhaust shooting straight back melted some plastic pieces on my hitch-mounted bike rack. Also melted the rear tire on my mountain bike.
Had to go to the closest parts store and get a turn down. And also had to buy a new tire.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
