Several problems with my '92 Cherokee Laredo - JeepForum.com
post #1 of 5 Old 10-16-2011, 04:10 PM Thread Starter
shrug
1992 FSJ Cherokee
I just recently bought a '92 Jeep Cherokee Laredo 4WD from my stepdad.
He sold it to me for $1600 dollars.
Here's the rub..
I SUCK with cars.
My jeep is idling low when i come to a stop and eventually dies.
For right now, I put it in neutral and hold my foot on the gas.
Also..
My front seat is bent back badly and was wondering if anyone had any tips on how to get it straightened out again.
ALSO...
My power steering fluid is leaking.
I went to Autozone and they told me the hose was leaking.
Any suggestions on how to fix that?
Lastly..
Sometimes my jeep won't start.
I'll be in park and it wont start, so I shift to neutral and it starts.
Obviously not a major problem, just wondering what causes it.
shrug is offline
post #2 of 5 Old 10-16-2011, 05:13 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Here is a perfect place to start -->> http://www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/
Next, buy a Genuine Jeep Factory Service Manual for your Cherokee. Haynes and Chilton's are OK for oil changes and brake jobs but they leave out lots of repair steps and are full of mistakes.
Give your Cherokee a full tune-up. Clean the Idle Air Controller and the throttle body.
Clean or replace the Neutral Safety Switch (NSS).
Find the junkyard and buy a new seat. You can put your upholstery on the new seat if needed.
Buy and install a new hose.
Cleaning the Idle Air Controller (IAC) :
Purchase sensor safe Throttle Body cleaner spray.
1. Remove the Throttle body from the intake manifold.
2. Remove the IAC with a TORX 15 driver (2 bolts)
3. Gently wiggle out the IAC from the throttle body
4. Clean the IAC with Throttle Body Cleaner (not carburetor cleaner). Use cleaner, a rag, and a toothbrush. Be gentle; don’t twist or pull on the pintle as it is fragile and can be damaged easily
5. Also clean where the IAC seats in the throttle body with the same throttle body cleaner
6. While you have the Throttle Body off, give it a good cleaning also.
7. Reinstall IAC, the Throttle body, and check idle quality.
CJ7-Tim is offline
post #3 of 5 Old 10-16-2011, 05:43 PM Thread Starter
shrug
1992 FSJ Cherokee
Thanks so much! I was recommended to this site by a friend, So far it's be VERY helpful!
shrug is offline
post #4 of 5 Old 10-16-2011, 05:44 PM Thread Starter
shrug
1992 FSJ Cherokee
Oh! And was $1600 a fair price for the jeep? It's in good condition other than the problems I listed.
shrug is offline
post #5 of 5 Old 10-17-2011, 09:41 AM
unkajeffy
Around TN its pretty average at least. Pricewise I mean.
Michigan Yankee in Redneck Land
unkajeffy is offline
cherokee , help needed
89 Cherokee laredo engine problems horsesforlife XJ Cherokee Technical Forum 25 04-24-2011 07:05 AM
98 Jeep Grand Cherokee Laredo Light Problems cmpunk1212 XJ Cherokee Technical Forum 1 03-29-2010 07:23 PM
89 cherokee laredo problems. blndreaper XJ Cherokee Technical Forum 13 03-12-2010 10:27 PM
92 xj laredo ac problems ski14dxb XJ Cherokee Technical Forum 0 05-15-2009 06:30 AM
Problems with my 88 Laredo Jeepin88Laredo XJ Cherokee Technical Forum 6 08-10-2002 09:46 AM
