Quantcast Settle a bet!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Settle a bet!!!
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 10-25-2009, 08:20 PM   #1
TaylorsTJ
Settle a bet!!!
Okay guys, me and my father have been back and forth to each other about how I warm my jeeps up to 100 degrees before I drive them anywhere. According to him a vehicle should not idle at all and should be driven right away albeit a little slower than normal. I firmly believe in letting the valves seat properly before driving the 4.0 I6. Both my jeeps have 180,000 miles and I have been doing this practice since I bought them and have never had an issue. So I ask, how many of you let your jeep warm up before driving???
TaylorsTJ is offline   Reply With Quote
Old 10-25-2009, 08:22 PM   #2
Kenbo-Slice
" Volkswagen "
Kenbo-Slice's Avatar
I do, every day it is colder than 30 degrees or so. Unless it is an emercency or I am running late.
Jeep build up...ONGOING Jeep build up...ONGOING
R.I.P. Tow Pig Dually build
Rear bumper/spare tire carrier build
Track bar bracket fabrication
AtoZ cage install/build
NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles!
Kenbo-Slice is offline   Reply With Quote
Old 10-25-2009, 08:26 PM   #3
skyway0018746
yeah i also believe in warming my motors up a little before driving them unless im late or an emergency but even then im light on the gas
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline   Reply With Quote
Old 10-25-2009, 08:31 PM   #4
TaylorsTJ
C'mon guys I don't feel like washing (gulp) a passat
Old 10-25-2009, 08:33 PM   #5
Zembonez
Start mine up and let it run a few seconds... and then I am off. Never have let one "warm up" before driving it. The engine is a purely mechanical beast. It does not "know" if it is moving a vehicle or not. As long as it has oil pressure, it is good to go.
Zembonez - XJ ADDICT - 2000 XJ (my new project) - 2007 GMC Sierra - 09 Scion xB - TruckModCentral - My Truck Forum
Originally Posted by Cowboy Cadillac
Canada has 4 seasons...Almost winter, winter, still winter and road construction
Zembonez is offline   Reply With Quote
Old 10-25-2009, 08:38 PM   #6
gratefulneal
Most definitely warm it up! I think the fluids need to run for a few minutes prior to driving it away...it's one thing if you have already been driving it...whole different deal if it has sat for awhile.
Both of my XJ's had over 200 K on them...so I guess it worked for me
Now, if I could only get my wife to do the same.....
Do as you choose, not as you're told
gratefulneal is offline   Reply With Quote
Old 10-25-2009, 08:39 PM   #7
bamajeepjunkie
1991 XJ Cherokee
Def good to warm it up, I try to on all my engines get them up to operating temp before putting a load on the engine the big rigs do this and have done this for years. I alway's warm my race quad up berfore tuning or racing. I've put over 200k on all my jeeps and have yet to blow up a motor (yet).
go here now--->http://jeepitreal.com/forum/ please.
91 red xj 4.0 ho ax-15 4.5" rockkrawler 33"bfg m/t
88 red xj 4.0 h.o. conversion,hack fenders f/r,cb w/ p.a.,apc 150w lights
95 z71 chevy 2" lift 33" trail kings
pardon my poor typin/english
http://www.mudbog.net/forum/
bamajeepjunkie is offline   Reply With Quote
Old 10-25-2009, 08:41 PM   #8
BigBearXJ
Ding Ding!
We have a winner!
Eat, Jeep and be Merry.
BigBearXJ is offline   Reply With Quote
Old 10-25-2009, 08:44 PM   #9
Zembonez
Well... everybody FEELS better about warming up their rigs, but there is exactly zero scientific evidence that it has any effect on the longevity of an engine. The engine may run more efficiently at operating temperature but it has no bearing on anything mechanical.
No harm will come from warming up if that's what you want to do. I'll be the guy a few miles down the road...
Old 10-25-2009, 08:44 PM   #10
junkyarddog
Normally I only warm it up when it is winter. Hard to see out of a windshield when it is iced over
junkyarddog is offline   Reply With Quote
Old 10-25-2009, 08:47 PM   #11
pentastar01
As long as the oil pressure is tip-top your good to go. I'll give mine a minute or two, just to let the idle calm down, but other than that I'm off.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline   Reply With Quote
Old 10-25-2009, 08:49 PM   #12
TaylorsTJ
In the summer I'm off in like 2min. But since its been getting colder i like for it to be at temp. Also I might add that along with most I have the "Chatter" that goes away once at temp, Thats why I generally give it a few mins.
Old 10-25-2009, 08:54 PM   #13
c0ncEpT
1995 XJ Cherokee
Anytime it starts getting cold outside I like to let mine run for at least 1 min. When its really cold outside (30 or below) I usually let it warm up for a full 10mins before I leave in the morning.
If for some reason I don't have time to let it warm up I take it very slow.
c0ncEpT is offline   Reply With Quote
Old 10-25-2009, 08:58 PM   #14
bamajeepjunkie
1991 XJ Cherokee
It doesn't care if it's under a load?? As in the pushrods and the other steel in an engine- don't expand when hot and affect bearings/seals etc. Are they not engineered to run at operating temp, I don't really think you'll cause much harm not warming up but I strongly believe you will add life by doing so, and thought that was the purpose of the post.
Old 10-25-2009, 09:16 PM   #15
MrNate
1997 XJ Cherokee
I only warmed up vehicles like that if they tended to stall out when they were cold. My '72 El Camino, for instance. It was either let it warm up fully or brake with the left foot and massage the throttle with my right at every light for 10 minutes.
MrNate is offline   Reply With Quote
Glock Forum
