setting ignition timing??? - JeepForum.com
post #1 of 5 Old 01-16-2006, 06:48 PM Thread Starter
rguy
I need some help setting the ignition timing on a 1988 cherokee.
I'm dropping in a new block and using the old distributor. Is there something I need to do to disable the timing advance? The tag/decal on the firewall says the timing is not adjustable so how do I know when it's correct.
I assume that I'll need to find the no.1 cylinder and match the rotor button to the no. 1 plug wire blah blah blah, but beyond that what else do I need to do to get it running and set the timing?
many thanks.
Rob
Rob
'90 Jeep Wrangler 4cyl.
rguy is offline
post #2 of 5 Old 01-16-2006, 06:57 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That's all you'll need to do. The PCM will adjust timing more or less once it starts up.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 5 Old 01-17-2006, 10:01 AM Thread Starter
rguy
so then there isn't a base timing that needs to set first, right?
thanks.
Rob
rguy is offline
post #4 of 5 Old 01-17-2006, 11:28 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
No base timing. ECU does it all. You have to be dead on when installing the distributor though. On tooth off will let it run, but it will run really poorly.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #5 of 5 Old 01-17-2006, 11:41 PM Thread Starter
rguy
wow.
thanks guys.
Rob
Rob
rguy is offline
heater fan only has high setting. and My brake lights work with no key in ignition. bootht99 XJ Cherokee Technical Forum 4 11-19-2009 10:14 AM
Ignition timing drew4x4 XJ Cherokee Technical Forum 6 09-17-2009 05:09 PM
Where's the "ACC' setting on the ignition key? 4.0H.O.XJ XJ Cherokee Technical Forum 10 11-24-2006 12:08 AM
Ignition timing 90 Jeep XJ Cherokee Technical Forum 3 08-05-2004 01:45 AM
Setting the timing on new motor Mr98Pontiac XJ Cherokee Technical Forum 2 12-11-2002 12:21 PM
