Serpentine belt replacement - JeepForum.com
post #1 of 7 Old 08-14-2013, 10:53 AM Thread Starter
droopydawg
2015 KL Cherokee
1999 Cherokee Classic.
I can not find the SEARCH THREAD function on this board, so excuse me if this is something that is discussed over and over.
We used to own a '94 Grand Cherokee, and I still have the Service Manual for it, knowing that some things would be the same.....some.
Daughter just bought a '99 Cherokee, to drive back to college (from Chicago to Phoenix)
I just replaced the serpentine belt, and since this rig is not equipped with an automatic tensioner, I did the best I could to tighten it properly. I have torque wrenches, but from reading the manual from the Grand Cherokee, I need a special belt tensioner tool to be able to check that the belt is tightened to 180 - 200 ft pounds.
I have called a few shops and they check it by feel. Since daughter has a 1800 mile road trip this weekend, I dont want to go by "feel".
Can I use a torque wrench, or is it truely a different tool?
If I can use my torque wrench, how to I do so? I would think that the (approx 15mm) adjuster bolt would break off long before I got to 180-200ft lbs.
Thx
Drew in Chicago
droopydawg is offline
post #2 of 7 Old 08-14-2013, 11:10 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You need a Krikit belt tension gauge. for the XJ Cherokee. The spec you saw is probably for the belt, and not for the adjusting bolt. The spec is probably inch/lbs, not foot/lbs.
CJ7-Tim is offline
post #3 of 7 Old 08-14-2013, 11:57 AM Thread Starter
droopydawg
2015 KL Cherokee
Yep, the spec is for the belt. I forget things can be in in/lbs. Thx
Drew Mobley
Lake Forest, Ill-annoying (Chicago)
'99 Cherokee Classic 4.0, '05 Nissan Frontier SE 4x4, '12 VW Beetle (wife's car), A bunch of motorcycles
post #4 of 7 Old 08-14-2013, 01:18 PM Thread Starter
droopydawg
2015 KL Cherokee
I just downloaded the Pacific Coast Manual. It just specifies 180 - 200 lbs. Does not specify inch or foot lbs. I guess the Krikit doesnt work like that, in inches or feet.
Drew Mobley
post #5 of 7 Old 08-14-2013, 05:20 PM
CJ7-Tim
CJ7-Tim's Avatar
IDK, I always do the belt tension by feel.
Whatever the Krikit is calibrated for, it will do the job correctly.
CJ7-Tim is offline
post #6 of 7 Old 08-15-2013, 06:32 AM
MossGreen97
1997 XJ Cherokee
NAPA would have the Krikit tool. I couldn't find the part no., but that is where I got mine. It's around 10-12 bucks IIRC. Really easy to use.
'97 XJ Moss Green Metallic. 2DR. 2WD AW4 tow pkg.,3.73 gears. Firestone Destination A/T 225/75x15.
MossGreen97 is offline
post #7 of 7 Old 08-16-2013, 09:56 AM Thread Starter
droopydawg
2015 KL Cherokee
A senior tech at local JEEP dealer checked it out and said I was right on the money. yay me. With wife and daughter driving to Az on sunday, in a rig that was just purchased 6 days ago, I dont want to take any chances on a breakdown. Thx
Drew Mobley
