Serpentine Belt/Power Steering Pump - JeepForum.com
post #1 of 5 Old 08-25-2012, 03:41 PM Thread Starter
YourJeepsAllWet
1995 XJ Cherokee
I have a 1995 Cherokee Sport with a 4.0. I recently had to replace the water pump, but now my issue is getting the serpentine belt back on. I loosened the nut underneath the pulley, and I turned the torquing bolt (which is also located underneath the power steering pump). Problem is, when I turn that bolt, it extends out instead of moving the pump. I've tried loosening the other bolts that hold it in place, but I still cannot get it to move. Is there something else I need to be doing?
YourJeepsAllWet is offline
post #2 of 5 Old 08-25-2012, 03:53 PM
overlandchris
Did you loosen the bolt on the pully itself...... To Adjust the belt first loosen the bolt holding the pully down then adjust the bolt on the pully bracke. If u look down it in sideways on an angle it's 15mm
4.7 V8 H.O. The Chevy 302 of Jeep Engines. Roar...
2004 Grand Cherokee Overland, Midnight Blue Pearl.
Rusty's 2" Budget boost, It Goes fast
Project "Shamrock": 96 Cherokee country, black, I6 HO, ZJ 242, 4.5 Rustys, 33" Mud terrains
My build:
overlandchris is offline
post #3 of 5 Old 08-25-2012, 03:57 PM
overlandchris
First loosen that
Then adjust that bolt to tighten or loosen the pully
My build:
post #4 of 5 Old 08-25-2012, 04:07 PM Thread Starter
YourJeepsAllWet
1995 XJ Cherokee
I found the problem. There are two bolts on the backside of the power steering pump that need to be loosened. I only located and loosened one. I've since loosened it and got the belt back on.
post #5 of 5 Old 08-25-2012, 08:16 PM
AZ Jeff
2014 JK Wrangler
Originally Posted by overlandchris View Post
Attachment 459717
First loosen that
Attachment 459718
Chris,
You are showing the tensioning system for the 97+. The OP's model uses a jackscrew that faces the airbox, and there are bolts on both the front and back of the PS pump that must be loosened to adjust tension.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
belt , power , pump , serpentine , steering
Serpentine belt squeal, new belt & tensioned V-R XJ Cherokee Technical Forum 2 11-27-2011 09:46 AM
Power Steering Pump Failure? Loose Belt? alexk243 XJ Cherokee Technical Forum 8 03-08-2011 11:02 PM
Need new water pump and power steering pump kylec XJ Cherokee Technical Forum 3 03-31-2010 12:57 PM
Power steering belt adjustment klockdoc XJ Cherokee Technical Forum 2 03-16-2009 10:19 AM
Power Steering + Serpentine Belt Off, Help!!! :D verrive XJ Cherokee Technical Forum 3 02-18-2004 07:28 PM
