serpentine belt diagram - JeepForum.com
post #1 of 5 Old 11-24-2004, 06:10 PM Thread Starter
Doolittle
Doolittle's Avatar
Question serpentine belt diagram
Hey guys,
I need to put back on my serp belt, but the part of the shroud that has the diagram on it broke off, does anyone have one, or know a link to one?
I did the search, got nothing,
also,
I still can't figure out how my fan is shifting forward, so any help there would rock.
thanks
jon
1995 Jeep Cherokee
4WD 2Dr SE
Emerald Green on Charcoal
4.0 Litre HO 5-Speed
Command Trac
D30/8.25
3in. BDS Lift
BDS shocks w/yellow boots
_Tires_
Front: noname 235's
Rear:(new)31x11.50 uniroyal larado rv's
I don't give a rats *** about online jeep clubs jeep club member # 10010101100101001
Doolittle is offline
post #2 of 5 Old 11-24-2004, 06:30 PM Thread Starter
Doolittle
Doolittle's Avatar
yeah, I found one ,
http://autorepair.about.com/library/...bl506a-lib.htm
thanks me
1995 Jeep Cherokee
4WD 2Dr SE
Command Trac
D30/8.25
3in. BDS Lift
_Tires_
Front: noname 235's
post #3 of 5 Old 11-24-2004, 10:21 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If the fan is hitting the rad, it could be a bad motor mount. Something to look into anyway.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 5 Old 11-25-2004, 09:06 AM Thread Starter
Doolittle
Doolittle's Avatar
would that motor mount be something I could check myself, what should I look for?
I can hold onto the fan and shake the engine a little, but nothing outrageous.
1995 Jeep Cherokee
4WD 2Dr SE
Command Trac
D30/8.25
3in. BDS Lift
_Tires_
Front: noname 235's
post #5 of 5 Old 04-01-2013, 10:12 AM
habbyguy
Believe me, the engine moves more under torque than you're going to be able to move it by hand. Just get under the vehicle and look at the motor mounts... it's not rocket science. If the motor is moving enough for the fan to get into the shroud because of bad motor mounts, it should be pretty obvious. The other thing to check is that your shroud isn't loose (mine got loose and was very infrequently contacting the fan - took me a little while to actually find the source of the noise).
habbyguy is offline
serpentine belt diagram edwardj2 XJ Cherokee Technical Forum 2 12-27-2009 06:14 PM
i need serpentine belt diagram please nickwygant MJ Comanche Technical Forum 1 07-15-2009 01:36 PM
serpentine belt...? bezerk XJ Cherokee Technical Forum 1 10-16-2006 05:45 AM
Serpentine Belt Help XJChris98 XJ Cherokee Technical Forum 6 10-01-2006 11:05 AM
serpentine belt diagram midnightmoonlig XJ Cherokee Technical Forum 4 07-09-2005 08:22 PM
