Serp. Belt frayed, got wound into fan!!! - JeepForum.com
post #1 of 4 Old 01-20-2014, 04:07 PM Thread Starter
coyotegal
the fan quit moving and the water pump got burnt out.. I already changed the water pump out and put a new belt. But now the jeep wont run right. It doesn't even want to start but after three or four tries, it starts but when I give it gas, it dies and sometimes it reves up without me giving it any gas. I'm sure it won't run down the road. Could my timing chain be causing this??? Or???? Thanks!
'92 Jeep Cherokee 2WD 4.0L MFI ........................... "I talk to myself, especially in the car." ~Chris Pine
coyotegal is offline
post #2 of 4 Old 01-20-2014, 05:05 PM
landude
Sounds like the belt isn't routed correctly...
Is there a diagram on your fan shroud?
landude is offline
post #3 of 4 Old 01-20-2014, 06:59 PM Thread Starter
coyotegal
I checked the diagram and double checked it and it's routed right. Thanks ;0)
post #4 of 4 Old 01-21-2014, 08:21 AM
Paradise XJ
1988 MJ Comanche
Smooth side on the shiny pulleys...ribbed side on the ...ribbed pulleys. See that you didn't upset any important vac lines...like the one to/from the MAP sensor.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
