Serp Belt - JeepForum.com
post #1 of 12 Old 08-03-2007, 11:16 AM Thread Starter
MyBlackXJ242
Serp Belt
Uh, I hate to be a pain and sound like a noob...
But there isn't a listing in the FAQ for serp belt swap for anything above a 95. My Jeep is a 00 and i'm major difficulty wrapping my brain around just how i'm supposed to get it off without crushing my hand or talking the power sttering pump off.
2000 Cherokee Sport
Jet Black, AW4,NP231,8.25 Rear, 30 Front.
No More Autolocker
Waag Brush Gaurd x2 KC's,
Sold the Wilderness Rack x4 KC's
"If I wanted a HUMMER I'd call your sister"
MyBlackXJ242 is offline
post #2 of 12 Old 08-03-2007, 11:21 AM
laurxj
laurxj's Avatar
1991 XJ Cherokee
loosen the 2 bolts that hold the power steering pump on(so you can move it back and forth) then loosen the tensioner bolt(its under the power steering pump.....pretty long bolt. loosen that til you can pop the belt off....and the routing for the new belt should be on your fan shroud...if not heres the routing for a 98 XJ http://autorepair.about.com/library/...bl512a-lib.htm
if thats the same as yours
hope that helps
1991 XJ 4.5'' RE Super-Flex 31'' M/Ts on Cragar soft 8s..tons of other mods
1979 Pontiac Trans Am
1979 Monte Carlo
1974 Camaro worked 350, TH350 finished Summer 08...new obsession
2003 TJ 5spd...the new DD
laurxj is offline
post #3 of 12 Old 08-03-2007, 11:28 AM Thread Starter
MyBlackXJ242
Yeah the routing is on there and i see the long bolt (it's already pretty loose) I just thought i'd have to loosen the idler itself.
2000 Cherokee Sport
No More Autolocker
post #4 of 12 Old 08-03-2007, 11:31 AM
XJohnnyC
XJohnnyC's Avatar
Nope, don't touch the PS bolts. On later models, there's just two bolts. You are correct - you loosen the idler pulley bolt first. Here's my picture once again...
XJohnnyC is offline
post #5 of 12 Old 08-03-2007, 11:33 AM Thread Starter
MyBlackXJ242
You're a god sent, that is exactly what i thought...what size is thet bolt on the idler?
2000 Cherokee Sport
No More Autolocker
post #6 of 12 Old 08-03-2007, 11:33 AM
laurxj
laurxj's Avatar
1991 XJ Cherokee
sorry thought his was like mine
1979 Monte Carlo
laurxj is offline
post #7 of 12 Old 08-03-2007, 11:33 AM
mortalenema
mortalenema's Avatar
It just take a ridiculous amount of turns to loosen the tensioner enough. Air tools are the only easy way.
nm guess it's different for the newer ones.
mortalenema is offline
post #8 of 12 Old 08-03-2007, 11:35 AM
XJohnnyC
XJohnnyC's Avatar
IIRC, it is 15 mm. And you don't have to loosen it very much. It's easy with a ratcheting box wrench.
XJohnnyC is offline
post #9 of 12 Old 08-03-2007, 12:09 PM
XJK
The Guru of Nothing
XJK's Avatar
ya i dont remember it taking a long time at all, loosen the pully a bit then start loosening the tensioner takes 10-15 minutes max. its a very easy job.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #10 of 12 Old 08-03-2007, 03:38 PM
cc cherokee
cc cherokee's Avatar
I just put a Goodyear Gator on last night. I found it easier to pull the electric fan first. It's only a couple of 9/16 screws on my '96. Gives you more space to fit a socket (15mm) on the idler.
cc cherokee is offline
post #11 of 12 Old 08-03-2007, 04:01 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I'll add this thread to the Tech/FAQ and we will now have the serp belt loosen/tighten covered.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #12 of 12 Old 08-03-2007, 11:18 PM
filluptrk
I modified a 15mm wrench so the box end was flat instead of angled like most are, and it makes it much easier so I don't have to pull the fan. Phil
filluptrk is offline
Stupid belt tricks? Serp belt recommendations please diskman_1 XJ Cherokee Technical Forum 7 07-03-2008 11:45 PM
how the hell do i get the serp belt off? toates89 XJ Cherokee Technical Forum 10 01-08-2008 05:54 PM
shorter serp belt Finaddictfred XJ Cherokee Technical Forum 3 08-21-2006 08:56 AM
88 Serp Belt Help cherokee88p XJ Cherokee Technical Forum 1 01-29-2005 06:08 PM
New Serp Belt??? ddoffroad XJ Cherokee Technical Forum 2 01-11-2003 09:54 AM
