Seized/Tight as heck/Won't come out np231 drain/fill bolts... - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Seized/Tight as heck/Won't come out np231 drain/fill bolts...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-13-2009, 05:51 PM   #16
Carhlr
I've got a 2001 Cherokee sport i have the hex type also I just changed mine on Sunday I couldn't break them loose with a regular ratchet i used a breaker bar Loosened right up just make sure not to overtighten when you put them back in. I used Dextron III
Carhlr is offline   Reply With Quote Quick reply to this message
Unread 10-13-2009, 05:56 PM   #17
XJMuscle98
What I worried about is breaking the tcase mounts since it was flexing a little bit as a pushed on the hex key to loosen it.
I'm going to be using Valvoline Full-Synthetic ATF+4
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline   Reply With Quote Quick reply to this message
