Seized/Tight as heck/Won't come out np231 drain/fill bolts... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Seized/Tight as heck/Won't come out np231 drain/fill bolts...
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-13-2009, 03:51 PM   #1
XJMuscle98
Ugh, I finally decide to change the tcase fluid and they won't come out.
Any ideas?
I'm all out of PB Blaster and can't go anywhere right now so thats out of the question.
If I cut off part of my hex key and fit it into a 10mm socket, and then put it on the impact wrench will that be bad?
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline   Reply With Quote Quick reply to this message
Unread 10-13-2009, 03:54 PM   #2
JGriff99xj
Be careful with the impact, the case is aluminum. Try driving it for a bit to get the case good and warm. Take an ice cube and touch it to the drain bolts to make them cold. Then try it. We used to use hot and cold for things like this all the time and it usually works.
JGriff99xj is offline   Reply With Quote Quick reply to this message
Unread 10-13-2009, 03:55 PM   #3
XJMuscle98
Thats what I was worried about breaking something with the impact so I figured I'd ask.
It's warm right now from a 10 minute drive, not hot but warm.
I reckon they haven't been loosened in damn near 215k either.
Ronald Reagan
Currently: 10
Unread 10-13-2009, 04:17 PM   #4
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
hmmmm maybe I am just having a blonde day, but the drain plug on every 231 I have worked on was a 1 3/16" bolt, not a hex head. Maybe that is why you are having problems! The drain plug is under and to the left of the fill plug.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 10-13-2009, 04:18 PM   #5
XJMuscle98
some 231s its hex some its a bolt.
Ronald Reagan
Currently: 10
Unread 10-13-2009, 04:19 PM   #6
Diamond-x
1991 XJ Cherokee
Some are 1-3/16, some are hex. Go figure.
Diamond-x is offline   Reply With Quote Quick reply to this message
Unread 10-13-2009, 04:22 PM   #7
leftlanetruckin
XJ on 37's
Guess I have been lucky then.
@6 231j's and 2 231c's....always been a 1 3/16" bolt, same as fill plug.
Martin
http://www.jeepforum.com/forum/showthread.php?t=324622
Unread 10-13-2009, 04:25 PM   #8
XJMuscle98
That makes me angry.
Why the hell do I have to have a hex bolt
Ronald Reagan
Currently: 10
Unread 10-13-2009, 04:27 PM   #9
leftlanetruckin
XJ on 37's
not a clue, but if so, then do NOT hit it with the impact, it will probably shatter the t/case!
Unread 10-13-2009, 04:35 PM   #10
XJMuscle98
thought so, I've given up for the mean time...
if I can atleast get the fill bolt out then I can just suck it out
Ronald Reagan
Currently: 10
Unread 10-13-2009, 04:35 PM   #11
JGriff99xj
Use plenty of penetrating oil. When trying to get something steel out of aluminum it can be a PITA! I have some CRC FREEZE OFF that i have to sometimes use. On the wife's 04 GC i had to take a propane torch to the rotors and use the freeze off on the hub center to get the old, warped rotors off. Temperature can be your friend in this case. Oh and i forgot to mention that trying to tighten a stubborn bolt and then trying to loosen it will sometimes work. At least it helps to get the penetrant in.
Unread 10-13-2009, 04:37 PM   #12
leftlanetruckin
XJ on 37's
I use a 12 volt extraction pump for the jet ski's we have as they have no drain hole for the engine oil. That would work good for the t/case.
I got mine from Bass Pro, under $25 IIRC.
Martin
Unread 10-13-2009, 05:06 PM   #13
Apostle
2015 KL Cherokee
allways use a breaker bar myself, never have problems. (current one is a 2ft long pipe from a vacuum cleaner). if the breaker bar bends, then i know it is torqued way too much and move to the heat cold.
did have to use the heat/cold on a rail bolt when i added the tc drop though, but no way to get a wrench on it, had to use vicegrips.
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline   Reply With Quote Quick reply to this message
Unread 10-13-2009, 05:06 PM   #14
Diamond-x
1991 XJ Cherokee
Heat and cold should work. Did you try the ice cube trick? or if you have a can of keyboard cleaner for a computer, if you turn it upside-down the propellant comes out and will freeze anything it hits. Run your car and hit it with that before breaking it loose.
Unread 10-13-2009, 05:11 PM   #15
XJMuscle98
I do have one of them!
I'll try that tomorrow, thanks!
Well tomorrow or whenever I muster up enough initiative to try again.
Ronald Reagan
Currently: 10
