Seized/Tight as heck/Won't come out np231 drain/fill bolts... - Page 2 - JeepForum.com
post #16 of 17 Old 10-13-2009, 05:51 PM
Carhlr
I've got a 2001 Cherokee sport i have the hex type also I just changed mine on Sunday I couldn't break them loose with a regular ratchet i used a breaker bar Loosened right up just make sure not to overtighten when you put them back in. I used Dextron III
Carhlr is offline
post #17 of 17 Old 10-13-2009, 05:56 PM Thread Starter
XJMuscle98
What I worried about is breaking the tcase mounts since it was flexing a little bit as a pushed on the hex key to loosen it.
I'm going to be using Valvoline Full-Synthetic ATF+4
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
AW4 drain/fill plug locations 03rubiconMG XJ Cherokee Technical Forum 4 06-02-2009 03:09 PM
T-Case Drain/Fill Plug/Bolts 89bluexj XJ Cherokee Technical Forum 7 03-09-2009 08:35 PM
Transfer case fill and drain plug bizzo15 XJ Cherokee Technical Forum 6 10-26-2007 11:38 AM
Just did a AX15 Drain & Fill, a curiosity question oldbastard XJ Cherokee Technical Forum 1 07-15-2005 11:19 AM
loc tight on diff cover bolts? NJ82TJ XJ Cherokee Technical Forum 8 05-08-2005 09:02 PM
