Seam welding? - JeepForum.com
post #1 of 4 Old 02-09-2006, 11:30 AM Thread Starter
cj7guy
Seam welding?
I have read many posts about the unibody flexing, but when I search, I do not come up with anything on seam welding. I know a lot of people add cages, but that doesn't work all that well on a DD.
It's not a terribly uncommon practice for uni-body sports cars to be treated to some seam-welding for additional rigidity. Has anyone tried this on an XJ, and if so, what were the results?
Thanks,
Jon
07 JKU - 6spd - LSD rear
cj7guy is offline
post #2 of 4 Old 02-09-2006, 11:47 AM
katarn444
katarn444's Avatar
I have never heard of this before but I do not see how it would make the structure more rigid. My first thought is, there are not that many seems to begin with. The floor is made of only two pieces of sheetmetal. My second thought is the flex of a unibody does not come from spot welded seems but from the fact that the frame is made from fairly thin stamped sheet rather then a boxed tubing in a regular frame.
K
1989 Cherokee (A work in progress)
Up-country springs
New 18g floor
96 Grand Cherokee dual diaphram booster, master cylinder, PV
katarn444 is offline
post #3 of 4 Old 02-09-2006, 06:38 PM
gumcrew2
1991 XJ Cherokee
if you want to stiffen it up GOOD go get some 1/4" 3x3" angle iron and weld it on to the bottom and outside of the "frame" rails. It'll weight a bit, probably 100 pounds or so total, but it'll help alot to.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #4 of 4 Old 02-09-2006, 06:52 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
Thier are a few companies out there that sell stiffner's. Some of them bolt on, some of them are weld on.
T&J Performance
T&T Customs
Currie
I know thier are a few more out there aswell, just can't remember off the top of my head.
LEAD_NOT_FOLLOW is offline
inner fender: cut & fold pinch seam? the303hooligan XJ Cherokee Technical Forum 7 04-01-2009 07:30 AM
spot or seam weld in new floorboards? jersey_jim XJ Cherokee Technical Forum 6 10-21-2007 12:20 AM
Rocker panel pinch seam HCA-Bronco XJ Cherokee Technical Forum 5 01-18-2006 03:13 PM
So I just did Seam Foam, and no smoke came out WTF!?! Atl-atl XJ Cherokee Technical Forum 10 11-10-2004 11:36 AM
pinch seam on rear fenders silverxj2001 XJ Cherokee Technical Forum 3 05-12-2004 12:19 PM
