Quantcast Seafoam Made My Jeep Run Worse?? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Seafoam Made My Jeep Run Worse??
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 04-06-2009, 08:56 AM   #1
phmaris
I am just wondering if someone can shed some light on why my car runs worse after using seafoam?
It seems to idle worse and definitely does not start up as quick. Immediately after using 1/3 can of seafoam in the intake and 1/3 in the gas tank. I did not add to oil.
phmaris is offline   Reply With Quote
Old 04-06-2009, 08:59 AM   #2
rworks
Probably loosened up lots of crap in the fuel system. When did you last change out the fuel filter?
rworks is offline   Reply With Quote
Old 04-06-2009, 09:05 AM   #3
Yury
Yury's Avatar
what kind of plugs do you have? change them and see if it helps
Yury is offline   Reply With Quote
Old 04-06-2009, 09:35 AM   #4
Turtleonitshell
Run a tank or two of premium through it, should start to run better, not the first time I've heard of this happening.
Turtleonitshell is offline   Reply With Quote
Old 04-06-2009, 09:46 AM   #5
phmaris
I just replaced the plugs with the basic champion plugs everyone recommends in the fall. I also did new wires, cap, rotor.
I guess I will just run some premium through it and see what happens. I guess seafoam should be reserved for older XJ's that really need it. I was just bored and thought cleaning out the fuel system couldn't hurt anything since I dont know what the previous owner had done.
Old 04-06-2009, 09:47 AM   #6
xjpilot
you most likely loosened up some pretty big chunks, and the amount of seafoam you put in wasn't enough to completely dissolve them. I would put that other 1/3 can you've got left into maybe 6 gallons of gas, and run it. Then I'd get 1 more can, put 1/2 of it into a full tank and run that out. After that, your problems should be gone, just like the sludge.
my jeep has the confused prerunner syndrome....4.5" in the rear and 2" in the front.
Purple Jeep Club Member # 1
xjpilot is offline   Reply With Quote
Old 04-06-2009, 09:52 AM   #7
phmaris
Are you the Seafoam rep?
I'll give it a try. Thanks for the help.
Old 04-06-2009, 01:03 PM   #8
jeeptown
Big chunks of what??? Dont bother with premium gas, it has no effect. Seafoam= snakeoil
jeeptown is offline   Reply With Quote
Old 04-06-2009, 01:15 PM   #9
rc76
Are you saying snake oil will work too?
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...)
99 Cherokee Sport- Stock and Staying that Way (Wife's DD)
Christian Jeep Group Member #160
rc76 is offline   Reply With Quote
Old 04-06-2009, 01:22 PM   #10
CalebsXJ
Its not snake oil Loads of people have had good things come from it... I did it to my 2000, and definitely could tell the difference.
http://www.jeepforum.com/forum/f11/sea-foam-99405/
2000 Jeep XJ; Heated Leather; 5.5 w/ACOS; 32's BIGHORNS; RK 3 Link; RE Monotubes; Rock Sliders; Rustys TC Skid; Front & Rear Recovery; Cobra CB; Flo-Pro Exhaust; Airaid; Surco Rack; HD Steering Crossover; IRO Adjustable Track Bar; SOLID d30 Cover; Recessed Winch Bumper; Gorilla Silver Back Series Winch; Hella 500 Lights...
CalebsXJ is offline   Reply With Quote
Old 04-06-2009, 02:35 PM   #11
99Greenmachine
yea i could tell a difference when i used it...just make sure you take it out on the interstate and DRIVE it real hard to get all the stuff burned out LOL
That was my favorite part
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 04-06-2009, 02:55 PM   #12
MXdude105
The first time you start it up after using seafoam, it should start hard and run rough, mine always does. Take it somewhere wide open and flog it for 10-15 minutes and the following time it starts, you should be golden.
-2000 XJ Cherokee Sport 4x4. 4.0L, NP231, c8.25, aw4, RC 3" AAL........SOLD
-1995 Mustang GT 302
MXdude105 is offline   Reply With Quote
Old 04-06-2009, 05:59 PM   #13
xjpilot
big chunks of sh*t, thats what carbon from the throttle body, chunks of sludge from the fuel tank. Everything that seafoam dislodges has to be forced through the entire fuel system and combustion process. I also disagree with your stand on premium...but thats a different argument. cactus = ice cream
Old 04-06-2009, 07:29 PM   #14
racerdude_9
whats sea foam? never seen it b4? where can i get it? is it like zmax but just doesnt eat my bearrings?
-1998 cherokee xj limited.. current daily driver.
-1991 dodge w250 cummins.. old daily driver and regular tire burner
racerdude_9 is offline   Reply With Quote
Old 04-06-2009, 09:19 PM   #15
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
If it doesn't clear up after a good hard drive, pull the plugs and check them out. You may have a piece of the carbon that the seafoam broke loose stuck in a plug causing it to foul. And I have used seafoam numerous times with good results.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Glock Forum
