Scan Tools and Code Readers - JeepForum.com
post #1 of 19 Old 07-20-2011, 08:39 AM Thread Starter
rsurran
Well I used the write-up on howtoECUcodes and when the sequence was complete only thing showing was the mileage. I'm assuming I had no codes. I about choked when I went searching for a DRB III. I see code readers for $49 and up on the web. What do I need more than the built-in diagnostic reader? My 2000 XJ is new to me and I'd like to verify no issues while all is well so when something happens I know what the baseline was. Thanks all.
rsurran is online now
post #2 of 19 Old 07-20-2011, 08:57 AM
AmbuGrl
AmbuGrl's Avatar
I dont believe that key on key off thing works on post 96 vehicles. We use an OBDII reader to read the codes on our Jeep (97-01)
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #3 of 19 Old 07-20-2011, 10:22 AM Thread Starter
rsurran
Thanks AmbuGrl. Would you remember what you paid/where you got it? BTW we are neighbors up here on the Eastern Shore.
post #4 of 19 Old 07-20-2011, 10:28 AM
Carves
ScanGauge is the common one ....
Theres others available ... and you even get i-phone blue pod thingymajigs programmes that display the OBDII info on the stereo system screen
Carves is offline
post #5 of 19 Old 07-20-2011, 10:44 AM Thread Starter
rsurran
Thanks Carves, I'll check it out.
post #6 of 19 Old 07-20-2011, 10:48 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Just Google ODB-II Code Reader, go on Amazon.com, eBay.com, or stop by your local auto parts store. I got an inexpensive code reader from HarborFreight.com on sale for $39.
CJ7-Tim is offline
post #7 of 19 Old 07-20-2011, 02:02 PM Thread Starter
rsurran
Thanks Tim. I've been looking at ODB II readers since AmbuGrl's post. Lots of choices.
post #8 of 19 Old 07-21-2011, 09:45 PM
sbxj
sbxj's Avatar
I just picked up an Actron (recommended by a JF user) for less than $60 on Amazon.
Let me know when you find the connector.
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #9 of 19 Old 07-22-2011, 06:37 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Actron, Innova, Equus are excellent choices.
Solid reputable manufacturer, great prices.
amazon.com is the place to shop for them
Be SURE to get one that allows you to clear (erase) the codes. That is a very important function. Most of them I believe have this function except for the el-cheapos, which I'd stay away from. For a few bucks more, you can get one of the above brands.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #10 of 19 Old 07-22-2011, 07:54 AM Thread Starter
rsurran
Thanks TJ and all, I will get one of those you mentioned that can clear codes.
post #11 of 19 Old 07-22-2011, 07:59 AM
whitexj98
I got an actron from sears, I got the cheapest one that could still read pids, its pretty helpfull if your trying to diag somthing.
whitexj98 is offline
post #12 of 19 Old 07-10-2013, 02:02 PM
Hamid
Hamid's Avatar
2015 WK
I just wonder if we really need the DRBIII scan tool for our Cherokees DTC !!!!, will the OBDII code readers be enough to retrieve all codes?.
What can the DRBIII do that all other scan tool brands cannot do.
DRBIII scanner cannot be found for less than 2000 bucks.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #13 of 19 Old 07-10-2013, 06:54 PM
CJ7-Tim
CJ7-Tim's Avatar
OBD-II trouble code scanners will read the Check Engine Light trouble codes and enable you to erase the codes. Some trouble code readers will also read ABS brakes and some will also display live data from your engine sensors.
DRB-III diagnostic scan tools can reprogram your engine computer, as well as read codes and display live data.
CJ7-Tim is offline
post #14 of 19 Old 07-10-2013, 10:50 PM
Fezwick
I bought this code reader and it works pretty well. It's bare bones in what it can do, but it gets the job done. At under $20 you can't complain.
Fezwick is offline
post #15 of 19 Old 07-11-2013, 07:20 PM
Glavus
This is the one I have - http://www.amazon.com/3130-Diagnosti.../dp/B000KID31K
It can read and erase codes and show live data
I recommend this one as well - http://www.amazon.com/Actron-CP9185-...Actron+scanner
Glavus is offline
Scan Tool Moekin XJ Cherokee Technical Forum 14 01-16-2008 01:28 PM
How do you scan the ECM on an 87 dlagrua MJ Comanche Technical Forum 5 06-29-2006 11:02 AM
obd readers john1998 XJ Cherokee Technical Forum 8 02-21-2006 03:36 PM
code scan on OBD-I jfw432 XJ Cherokee Technical Forum 3 02-02-2004 10:48 PM
ATTN Quadratic readers...HELP! phokur XJ Cherokee Technical Forum 7 11-25-2003 09:45 PM
