Quantcast Say I want more inches... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Say I want more inches...
Old 03-07-2006, 02:58 PM   #1
00xj54
well, I don't right now. But for when I do....
What does I do?
I have 2 spacers up from front... Could I just add bigger springs.
I have 2.5 AAL. Could I just get shackels?
[I]00' XJ Sport. 4.0 I6.
[B]|15" Canyon Crawlers | 30x9.5 Bridgestone Dueler A/T Revos | [Lifted (2" Teraflex Spacers | 2.5" RE AAL | Edlebrocks IAS)| K&N Homebrew Intake | Flow Master 70 |Clear Corners/Side Markers| Class III Hidden Hitch | C4x4 Fronts Tow Hooks | JKS Discos | Surco Safari Rack | Hella 500s |
00xj54 is offline   Reply With Quote
Old 03-07-2006, 03:04 PM   #2
andrew2516
Looks like you already answered your own questions.
You could also add 1" blocks to the rear if you have ok springs.
93 Cherokee Sport 4.0
5 speed(ax15), np231
8" Lift
36" TSL's on RockCrawler rims
www.PGHOFFROAD.com
andrew2516 is offline   Reply With Quote
Old 03-07-2006, 03:06 PM   #3
x550x
1960 CJ3B
I think you are pretty much maxed out on spacers. I would start saving for new front springs. Maybe a 3" or 4" coil. Keep the spacers for when you want to go even bigger. Yes, it will happen.
A lift shackle will be fine for the rear. If you wheel it a lot, it will eventually sag your springs. At that point you can just replace the packs with new ones.
As you already know, there is no end to the madness.
FOR SALE - 1960 Willys CJ3B - Odd Fire V6 - T177 - Dana 300 - D30 - D44 - 33x12.50 Super Swampers
x550x is offline   Reply With Quote
Old 03-07-2006, 03:12 PM   #4
Muddy Cherokee
But as you go higher you're going to run into other stuff too like needing an SYE/CV driveshaft and probably lower control arms too.
[SIZE="1"]1996 Cherokee Sport
4.0L HO, AX-15, NP 231
RE 4.5" Lift, 32" Dunlop Mud Rovers, RE Hack'n'Tap, CV Driveshaft, D30/D44, 4.10's, Aussie Lockers, ZJ Tierod, F/R recovery points[/SIZE]
Muddy Cherokee is offline   Reply With Quote
Old 03-07-2006, 03:34 PM   #5
00xj54
Yes, I thought so. How's that stuff work? After how many inches will I need it? and what a about t-case drop.
Old 03-07-2006, 04:31 PM   #6
Blake
Redefining body roll
Blake's Avatar
I get junk email all the time about adding a few more inches.
2005 G35 Sedan
Sport Package | Mostly Stock
1999.5 Ford F250
6.8l V10 l Auto l 4WD l 4" Spring Lift | 4.30 Gears | 35" Treadwright MT/R's
1987 Mercedes 300D Turbo
Stock | European Headlight Conversion!!1!
Blake is offline   Reply With Quote
Old 03-07-2006, 04:45 PM   #7
andrew2516
With a 2000 you will probably need a SYE at 4 or above...it seems like newer XJ's(97+) get vibes at lower heights compared to older XJ's.
8" Lift
www.PGHOFFROAD.com
Old 03-07-2006, 06:06 PM   #8
Bowhunter46563
And I thought i was the only one.
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters
Bowhunter46563 is offline   Reply With Quote
Old 03-07-2006, 06:12 PM   #9
firehawk
If I sent away to all those e-mails, I'd have to use a hose reel.
2000 Cherokee Sport
Patriot Blue
4.0L / AW4 / NP 242, blah, blah, blah...
A lot of parts that cost a lot of money
xjTalk.com
firehawk is offline   Reply With Quote
Old 03-07-2006, 10:12 PM   #10
Rock Kustoms
LMAO....
find a smaller hole, its easier than adding inches
Rock Kustoms is offline   Reply With Quote
Old 03-07-2006, 11:12 PM   #11
00xj54
Originally Posted by tealcherokee
LMAO....
That's easy for you to say with your 7 inches.
Glock Forum
