Sanden 709T AC Clutch Bearing Question!! - JeepForum.com
post #1 of 21 Old 09-29-2008, 05:09 PM Thread Starter
Jeeps4u
Jeeps4u's Avatar
1997 XJ Cherokee
Hey Guys,
Man O' Man! So my bearing in my AC clutch assembly is going.
1997 XJ Sport 4.0
Sanden 709T AC Compressor (Model # U 4691)
I was going to just replace the bearing, but it appears that the bearing is fixed in place by the tabs?? My machine shop said they didn't think it could be removed without breaking the little tiny friggin tabs off. Can this bearing be removed and replaced?
I picked up a used compressor from a 2001 XJ ($85 salvage yard) thinking I could swap the pulley w/ bearing and/or clutch assembly. Turns out the 2001 compressor (Sanden 709T A01 - Model # 4826) pulley is recessed, the coil is a different size and the clutch assembly won't fit properly onto my compressor.
I am really, really trying to avoid pulling the whole compressor! Can my bearing be replaced?
Thanks for any pointers! -Aaron- Madison, WI
97' XJ Sport-4.0L I6, Forest Green, full-faced brushguard, (6) spotbeam headlights, 3" Rough Country w/ 3.5" Pro Comp packs, newly added magnaflow cat and dyno muffler
Jeeps4u is offline
post #2 of 21 Old 09-29-2008, 06:32 PM
Ed Rico
1997 XJ Cherokee
The short answer is yes, the clutch pulley bearing can be replaced. As you've noted, the bearing is staked in from the compressor side to hold it in place in the pulley. On my '98 with that same Sanden compressor, I used a rotary file in an angle grinder to (carefully) remove the metal from the pulley where it was staked, after that it was straightforward to drive the bearing out through the back of the pulley. Once the new bearing is in place in the pulley (stick it in the freezer for awhile first), just use a hammer and chisel in several places around the perimeter of the bearing to restake it and hold it in place and you're ready to reinstall back onto the compressor snout.
That bearing was pretty expensive for a ball bearing. Don't bother trying to source one from a parts store, Autozone has 2 bearings listed that are both wrong and when I found the correct one at another store it listed for $90 or so. I ending up using the NSK p/n on the bearing to locate a new one from Motion Industries, the local NSK distributor here in Chicago. Was around $70, if I remember. Best part of all is that you never have to open the system to make the repair.
-Ed Rico
Ed Rico is offline
post #3 of 21 Old 09-29-2008, 08:18 PM Thread Starter
Jeeps4u
Jeeps4u's Avatar
1997 XJ Cherokee
Ed, thank you so much for the info. That is exactly the first hand advise I was looking to hear.
Has anyone else done this method of replacing the bearing?
Jeeps4u is offline
post #4 of 21 Old 09-30-2008, 04:19 AM
davet1960
davet1960's Avatar
1997 XJ Cherokee
yes, i had to order the bearing from Japan
davet1960 is offline
post #5 of 21 Old 12-12-2008, 01:19 PM Thread Starter
Jeeps4u
Jeeps4u's Avatar
1997 XJ Cherokee
I know it's been a while, but I just wanted to update this thread and help anyone that has this same dilemma. I replaced my a/c clutch bearing (from used compressor $90) by cutting out the old crap bearing and the new bearing using a dremel tool and various cutting bits. Then pounded the new one into my existing pulley wheel. So yeah, if your bearing goes, find a new one, cut the tabs off the pulley to free the bearing and you saved $150 or more by not having to buy the whole clutch assembly. Thanks for the tips guys!!
Jeeps4u is offline
post #6 of 21 Old 04-14-2009, 05:40 PM
eazy
what are the benefits from putting the new bearing into the freezer ?
eazy is offline
post #7 of 21 Old 04-14-2009, 06:52 PM
Ed Rico
1997 XJ Cherokee
Chilling the bearing shrinks it (very) slightly and makes it a bit easier to install in the bore of the pulley.
-Ed Rico
Ed Rico is offline
post #8 of 21 Old 06-03-2009, 07:18 PM
gnfoster
What if I don't have the part NSK number?
My bearing was completely destroyed. Does anyone still have the NSK part number of the bearing we're talking about? Can they maybe find it by description at Motion?
Thanks for any help!
gnfoster is offline
post #9 of 21 Old 06-06-2009, 08:46 AM
Ed Rico
1997 XJ Cherokee
Mine was an NSK 35BD219DUK. Dimensions are 55mm OD 35mm ID 20mm thick.
You should be able to cross-reference that into other bearing manufacturer's part numbers if you have to find a different supplier.
-Ed Rico
Ed Rico is offline
post #10 of 21 Old 06-08-2009, 04:43 PM
dickmgl
AC Compressor Clutch
I am replacing the clutch bearing on my AC compressor for '99 Jeep Cherokee Sport. How do I get the clutch off? The compressor is a Sanden #4691
dickmgl is offline
post #11 of 21 Old 06-08-2009, 05:19 PM
AZ Jeff
2014 JK Wrangler
Go here to download the manual on how to service the Sanden compressor: http://www.sanden.com/index.php?id=MTExOTk3OTEwNw6
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #12 of 21 Old 06-11-2009, 08:17 PM
multmigs
2003 WJ
what is the symptom of the bearing going bad?
multmigs is offline
post #13 of 21 Old 06-11-2009, 09:05 PM
AZ Jeff
2014 JK Wrangler
With the belt off the compressor, turning the pulley by hand will reveal noise and/or roughness as the pulley rotates.
AZ-Jeff
AZ Jeff is offline
post #14 of 21 Old 06-12-2009, 02:46 AM
srb43
Before you tear down,check to make sure when the bearing failed,it didn't tear up or overheat the front seal of the compressor.I wouldn't want to go through all the work,only to find out that you can't hold freon any more.Use an a/c sniffer to check for any leaks.
srb43 is offline
post #15 of 21 Old 08-29-2009, 03:28 PM
kkchevy3
what about a pully that feels tight but you can see wobbles just a tiny bit.
kkchevy3 is offline
AC clutch bearing gone bad jdcountryboy91 XJ Cherokee Technical Forum 12 09-11-2009 08:41 PM
Where to get A/C clutch bearing? bhanse4 XJ Cherokee Technical Forum 3 07-30-2008 05:55 PM
fan clutch idler bearing mustang78 XJ Cherokee Technical Forum 4 12-25-2007 05:10 PM
97 Clutch -- t/o bearing? QHays XJ Cherokee Technical Forum 1 09-29-2007 10:21 AM
Compressor clutch bearing ClassicUP XJ Cherokee Technical Forum 13 07-05-2007 09:49 PM
