#1 | |
rusty's tail light's
I recently aquired a set of rusty's rear tail light's. I have a 95xj does any body know how to wire them up? What i need is what color wire's from the xj need to hook up to the lights. Im going with one red tail light for light,break,and turn, and one clear for rev. I can not figure it out at all. I can almost get close but both end up turn signaling at the same time.What i need is to know what color wire from the xj goes to what color at the light. and does the rusty light ground to the bodyand if so what do you do with the xj grounds. Im an idiot i need a scamatic
#2 |
where did you get those?? i cant find them on their site?
#3 |
Not sure on the schematic but here's a link for jackdup: Rusty's Metal Taillights
#4 |
thanks for the link man..but i guess they dont make them for 97 plus
thanks anyway! |
#5 |
cool
has any one hooked these up before?
#6 |
in order to combine the stop, tail AND turn functions into one light per side, you need a trailer wiring harness and brain box, which is usually just a sealed box with the correct wiring done, and diodes to prevent backfeed.
It actually just be easier to keep it with the stock setup, run red and amber lights in the boxes, then figure out what to do for reverse lights
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups. PS: Installing HID's in stock housings is bad. Here is why. "When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009 |
#7 |
lights
the stop lights i have are light break turn combo, those wont work?
#8 |
Your jeep has running light combined with brake lights and turn is separated into the amber lens. To rewire brake turn and running light in the same red housing you need a trailer light adapter that interrupts brake light circuit so that it will blink.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25; 6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack Rock Sliders, K&N Panel Air filter, PSC steering box, I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$ |
#9 |
Here is an adapter-converter.http://www.nextag.com/Wesbar-ELECTRONIC-TAIL-LAMP-527615556/prices-html?nxtg=e4110a1c0520-7A4900313B7E9301
Not sure that I would get it from there search for tail light converter you don't need on that includes a isolation circuit. BTW most wall mart and auto part places should have one. Good luck and post picks once you GIT 'ER DONE! Chris
#10 |
do you need one for each of the light housing's?
#11 |
no, you need one, period. It installs behind where the spare tire is mounted. You need to run wire from the trailer junction box to the new housings though
#12 |
thanks alot
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
