Rusty's caused my DW..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Rusty's caused my DW.....
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 07-19-2009, 09:49 AM   #1
fla_cracker
1995 XJ Cherokee
OK, So I recently lifted my XJ. It's a 95'. I put 3.5" Rusty's leaf packs in the rear and 3" Rusty's coils in the front. The springs were not the problem.
Because my OE steering linkage looked wore out I purchased a Rusty's HD conversion. Not the "over the knuckle" kit just the heavy duty kit. It came with a new stabilizer and hardware.
Install was easy.
Pro's for the kit:
Thick tie rod and drag link material
Cheaper than other kits
can be made to "over the knuckle"
Cons:
"IT CAUSED MY DEATH WOBBLE!!!!!!!!!!!
after going through all the all the other variables and really watching my linkage work I found that the design of the HD kit allowed linkage play and free movement.
To make a long story short, after putting my old linkage back on the DW went away.
Take it for what its worth.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. "
Albert Einstein
Originally Posted by N2Fix View Post
"somewhere between really crappy and kind-of-crappy gas mileage."
fla_cracker is offline   Reply With Quote Quick reply to this message
Unread 07-19-2009, 11:09 AM   #2
bikedude189
1993 XJ Cherokee
somehow, that doesn't surprise me. at all...
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2009, 11:22 AM   #3
xjfever
xjfever's Avatar
1995 XJ Cherokee
IMO the currie system is the best bolt on kit on the market. Rusty's is okay for some parts, but trac-bars and steering are not a good investment from rusty's.
xjfever is offline   Reply With Quote Quick reply to this message
Unread 07-19-2009, 11:44 AM   #4
fla_cracker
1995 XJ Cherokee
I kinda figured that out the hard way. I hope this helps others "steer away" from poor design.
Albert Einstein
Unread 07-19-2009, 11:45 AM   #5
theducksguts
Good to know. Thanks man.
00 XJ Sport 0331 Victim
99 XJ Sport
98 TJ
Check out my Classifieds
theducksguts is offline   Reply With Quote Quick reply to this message
Unread 07-19-2009, 01:36 PM   #6
broncofire75
Send it back. Rusty is a good guy he'll make it right.
Thats a problem with the inverted T set-up not just rustys. It happens with the RR kit too.
So people use plastic washers in between the TREs. That seems to help a bit.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2009, 06:50 AM   #7
dcorn
Did you try to go 'over the knuckle' on the driver's side knuckle without drilling it out and getting an insert for it? This would most likely cause a lot of play in the steering.
2014 Jeep Grand Cherokee Summit
dcorn is offline   Reply With Quote Quick reply to this message
Unread 07-20-2009, 08:51 AM   #8
That1guy
2007 WK
Rusty's is horrible. I've heard too many stories about trackbars breaking to trust anything but their springs.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline   Reply With Quote Quick reply to this message
Unread 07-20-2009, 06:34 PM   #9
fla_cracker
1995 XJ Cherokee
Nope didn't do the OTK. It was installed in the usual configuration. The DW is caused because ball joint the connects the drag link to the tie rod is not mounted to the knuckle. Thus allowing the tie rod to "roll" when the pitman arm pushes or pulls it.
Albert Einstein
Unread 07-20-2009, 06:35 PM   #10
fla_cracker
1995 XJ Cherokee
Originally Posted by That1guy View Post
Rusty's is horrible. I've heard too many stories about trackbars breaking to truck anything but their springs.
My fault for not doing research before buying.
Albert Einstein
Unread 07-20-2009, 06:44 PM   #11
XJNUTTIER
I had the same issue with mine, I was running a 6.5" lift on my old 90 XJ, and it was good, but same thing, had some worn tie rods, and decided to buy the Rusty's kit and what a crappy deal that was. I spoke witht hem and they suggested a 1 degree toe in, and they said that would help out with the DW, so I was not the only person with that issue, and that was back in 2004 I installed it on my rig. I never found a happy medium with the kit, I eventually sold the Jeep witht hat kit on it, and I know now to never buy one again...
XJNUTTIER is offline   Reply With Quote Quick reply to this message
Unread 07-22-2009, 12:26 PM   #12
fla_cracker
1995 XJ Cherokee
So many victims of poor design............
Albert Einstein
Unread 07-22-2009, 01:44 PM   #13
stoneytj
your luck the welds didn't fail! lots of guys on naxja have had that issue. had my buddy bust 3 out of 4 ca's he bought from rusty's so far. i could weld better then his stuff with a battery!
only good thing i have heard about his stuff are the skids. no welds to f up!
RIP Keith Andrus 1985-2010 you will be missed buddy
build thread
http://www.jeepforum.com/forum/f22/s...1/#post8930381
stoneytj is offline   Reply With Quote Quick reply to this message
Unread 07-31-2009, 11:33 AM   #14
Npfiremedic107
Not to thread jack but has anyone put on or had any issues with the Iron Rock adj track bar?
Npfiremedic107 is offline   Reply With Quote Quick reply to this message
Unread 07-31-2009, 11:37 AM   #15
jjg214
nah, youll find more that people love IRO's stuff. go for the double shear track bar, i run it and its great.
jjg214 is offline   Reply With Quote Quick reply to this message
