Rusty Fog Lights? - JeepForum.com
post #1 of 4 Old 01-18-2011, 04:54 PM Thread Starter
jrb94zj
1994 ZJ
Rusty Fog Lights?
My passenger side fog light recently burnt out. After I removed the lens to change the bulb I found the metal piece in front of the bulb was completely rusty. I removed the drivers side for comparison and it was the same. These shouldn't be rusty, should they?
1994 ZJ Limited / 4.0 I6 / np249 tc
jrb94zj is offline
post #2 of 4 Old 01-18-2011, 06:45 PM
linkj79
Looks like a poor rubber seal. Moisture probably blew the light is there corrotion in the light socket. If the plug is not rusty put some dieletric greese (50cents at the parts store for a little packet) in the slot and on the connection points to the bulb. the use some weater stripe adhesive to but a thin line around the lens and the backside of that rubber seal to the housing before you put it back on. or buy new fixture.
linkj79 is offline
post #3 of 4 Old 01-18-2011, 11:06 PM Thread Starter
jrb94zj
1994 ZJ
So should I try to clean these up at all. I'm not sure if it will affect the output of the lights. I thought about sanding it down to make it shiny again.
jrb94zj is offline
post #4 of 4 Old 01-21-2011, 09:16 PM
linkj79
Depends on cost if it is cheaper to but the elbow grease into it then go ahead but if it is a $40 light and the bulb socket is rusty I would replace it
linkj79 is offline
fog lights , rust
Dash Instrument Panel Lights Tail Marker Lights Out - checked ALL fuses and lights g33p XJ Cherokee Technical Forum 13 03-29-2013 11:24 PM
rc an rusty aggiefan07 XJ Cherokee Technical Forum 12 04-04-2010 05:23 PM
Sorry, I am rusty on my XJs... BIGNUTT XJ Cherokee Technical Forum 7 11-02-2005 01:40 PM
Rusty XJ, what to do? NOVAggie XJ Cherokee Technical Forum 5 07-25-2005 08:22 PM
RE or Rusty? BrianXJ XJ Cherokee Technical Forum 21 08-03-2003 03:25 AM
