rust gone, engine next - JeepForum.com
post #1 of 5 Old 11-22-2012, 10:09 AM Thread Starter
jlsalani
just finished fixing the rust problem on my son's 2000 Cherokee..... moving on to the engine next. What would you guys suggest?? I am going to clean it up and look for leaks. I might have a rear main leak or it is running down the back of the block. Not very much, doesn't even make it to the ground except for a drop or two. I am a bit concerned about the head. Read way too many postings about the 2000 head cracking issue. I haven't noticed too much coolant loss but there seems to be a little. Should I just replace it and be done with it?? If so, where should I go to buy one that won't have the same issue. If I replace, what should I do while I have it opened up?? Jeep runs good, but needs a clean up.
jlsalani is offline
post #2 of 5 Old 11-22-2012, 10:30 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Threads about cracked 0331 heads far exceed actual cracked 0311 heads. If it ain't broke, ....... Cooling system preventative maintenance would be a better idea that swapping heads. RMS leaks are common.
CJ7-Tim is offline
post #3 of 5 Old 11-22-2012, 10:33 AM
austin6137
1990 XJ Cherokee
4.6 stroker
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #4 of 5 Old 11-22-2012, 08:38 PM
DezertXj88
1990 XJ Cherokee
4.2L mini stroker with a ported head & mid to high 9's for compression. Mines 9.2:1, stock cam at -4* vs factory -8*. Ported head LS1 valve train.. (2.00/1.55 valves turned down to 1.93/1.52) stock is 1.90/1.50
Anyway dynoed at 289/318 on a motor dyno running on 87oct. Not to shabby!
DezertXj88 is offline
post #5 of 5 Old 11-22-2012, 09:14 PM
bigbill888
My 96 4.0 ZJ used to leak oil from every place imaginable. After carefully cleaning up the CCV system, no mo leaks whatsoever.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
