Rust in the coolant reservoir - JeepForum.com
post #1 of 8 Old 04-17-2007, 05:08 PM Thread Starter
wizardPC
Hey guys,
I got a coolant flush about 7 months ago, and yesterday when I went to get an oil change they told me it needed to be done again. Well, first they told me that there was oil in the coolant and that the head gasket was leaking, but then the rust settled in the bottom and they revised their diagnosis.
The reservoir bottle has a good bit of chunky rust in the bottom, but after 10 minutes of sitting it has all settled. I popped off the radiator cap and the coolant there was brown.
I dont want to spend $150 getting another flush and have this crap again six months from now. When I had my alternator replaced a couple months ago they told me that the water pump pulley had some play in it and that it may be going bad.
So my bottom line question is: Where in the cooling system can rust be introduced?
Design previews and mad kid pics on
wizardPC is offline
post #2 of 8 Old 04-17-2007, 05:17 PM
Jmila1901
Jmila1901's Avatar
I want to say the radiator, look at the prices at your local parts store, should not be too expensive and its a pretty easy job. If i were you i would also replace the water pump.... Do you trust your skills? or are you going to take it to get done somewhere?
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline
post #3 of 8 Old 04-17-2007, 06:54 PM Thread Starter
wizardPC
I could probably replace the radiator, but replacing the water pump scares me. I replaced the exhaust manifold last year, but it took me 3 entire days :P
Aren't radiators aluminium, and therefore do not rust?
wizardPC is offline
post #4 of 8 Old 04-17-2007, 06:58 PM
alexrule123
alexrule123's Avatar
wow....that is a long time, but i have no room to talk. it took me three days to replace my front wheel bearings (it helps if you get the right hubs)
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #5 of 8 Old 04-17-2007, 07:58 PM
KamekLocked
KamekLocked's Avatar
That is most likely rust and scale from the entire cooling system that has collected in the overflow. Does not necessarily mean that the radiator is bad, just means the corrosion has happen between the iron block/head, heater core, radiator...
I would get another coolant flush done at a competent place and not a 15 minute oil change place...
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R
Flowmaster Delta 40 w/stock pipes
Optima Yellow Top l Custom Headlight Harness
Alpine CDA-9886
KamekLocked is offline
post #6 of 8 Old 04-17-2007, 08:14 PM
AZ Jeff
2014 JK Wrangler
Originally Posted by KamekLocked
corrosion has happen between the iron block or aluminium head.......
Just to note--the cylinder head on an XJ engine is cast iron, just like the block.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #7 of 8 Old 04-17-2007, 08:21 PM
curtjames37
curtjames37's Avatar
I used to work for Jiffy Lube and we did coolant flushes all the time. It basically consisted of pulling the lower radiator hose, draining, and refilling. I wouldn't let the guys there touch my Jeep with a ten foot pole.
You could do better work in your driveway than you will get at an oil change shop. Take it to a competent mechanic or do it yourself.
curtjames37 is offline
post #8 of 8 Old 04-17-2007, 08:26 PM
KamekLocked
Thanks for correcting that. I am so used to working of imports all day with cast blocks aluminium heads or all aluminium engines...
Alpine CDA-9886
Washer Fluid in Coolant Reservoir 98XJinME XJ Cherokee Technical Forum 4 10-11-2009 10:21 PM
4.0 seems to be leaking... coolant reservoir depletes cherocon XJ Cherokee Technical Forum 6 02-08-2009 08:24 PM
Coolant reservoir empty missyxj XJ Cherokee Technical Forum 10 12-02-2008 06:53 AM
01 Coolant Reservoir Gr8Swammee XJ Cherokee Technical Forum 6 12-17-2006 09:47 AM
Expansion reservoir - coolant trashman XJ Cherokee Technical Forum 14 03-06-2005 10:07 PM
